How to boot into a luks encrypted rootfs partition from initramfs on i.MX6ULZ?
skwang6272
Hi everyone,
I am trying to do disk encryption on i.MX6UL. The device is USB armory II. It has DCP and no CAAM.
This is my plan:
1、Two partitions. One for /boot, one for rootfs. Bootloader and kernel are stored in /boot and they are in plain text. The rootfs is encrypted by LUKS(DM-crpty).
2、Configure initramfs in the kernel. During the boot process, decrypt the encrypted rootfs and mount the root directory automatically.
3、LUKS uses file as key. At the same time this key file is encrypted with DCP.
Here is my question:
1、How to install the system on an already partitioned SD card?How to configure the encrypted file system?
2、How to configure initramfs to encrypt and load rootfs automatically?
I am just new to embedded development. Any suggestions, documentation and tutorials are welcome.
I have searched for similar issues
How to boot into a luks encrypted rootfs partition from initramfs on imx6 quad?
The document "Root filesystem encryption using DM-Crypt"  looks useful but I don't have permission to access it.
Thanks!
MikeAtMT
+1 looking for "Root filesystem encryption using DM-Crypt" - I've worked on this many years ago, but need to refresh my memory. Thank you!
r1cebank
I am not sure if you already figured this out, but recently I've modified the USB Armory's image builder script to support the encrypted rootfs you mentioned.
https://github.com/r1cebank/usbarmory-debian-base_image
Hope this helps.
Yuri
  Please refer to the following app note (assuming encrypted boot of U-boot and kernel).
"i.MX Encrypted Storage Using CAAM Secure Keys"
https://www.nxp.com/docs/en/application-note/AN12714.pdf
Yuri.
skwang6272
Thanks a lot!
But I have seen this doc. And I have no CAAM, only DCP. Are threy same?
Yuri
  If i.MX processor does not have CAAM - only software based DM-crypt
may be applied.
Yuri.
adde_ado
Hi Yuri,
Could you please send to me
"Root filesystem encryption using DM-Crypt" document?
I'm working with Imx8mm and I have same issue.
Adde
skwang6272
Thank you for your reply. Could you show me any docs explain how to preform software based DM-crypt?
btw Why can't DCP do what CAAM does?
Yuri
  Some material have been sent directly.
Yuri.
arunkrishnank
Dear Yuri,
Is it possible to share the document to me. I am attempting rootfs encryption on a i.MX 6 ULL
andreamengalli
Hello Yuri,
I am working on encryption on i.MX8Mmini.
Could I have access to the document "Root filesystem encryption using DM-Crypt"?
Thanks in advance.
YoussefDALIL
Hello @Yuri ,
Could I have also access to the document "Root filesystem encryption using DM-Crypt"
I really need this document to work on my project please.
Waiting for your reply
Yuri
@YoussefDALIL
In addition to AN12714 (i.MX Encrypted Storage Using CAAM Secure Keys) use
section 10.5 (Disk encryption acceleration) of i.MX Linux User's Guide.
https://www.nxp.com/webapp/Download?colCode=AN12714
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
 For specific customer's cases (OS releases) NXP Pro Support may be involved.
Yuri.
Yuri
parthitce
@YuriCould you please share the documents for dm-crypt to do with imx6ULL/imx6ULZ?
Parthiban N
Yuri
@parthitce
  I've sent You the file.
Yuri.
kmaincent
Hello Yuri,
I am also working on encryption.
Yuri
@kmaincent
  I've sent You some comments.
Yuri.
r1cebank
I am having the same question, is it possible to send me the same documents?
Yuri
@r1cebank
Done!
~Yuri.
gulsrb
Dear Mr. Yuri
It would be very much appreciated if you could also provide me with a copy of the "Root filesystem encryption using DM-Crypt" document.
Aleksandar
