How can I test the UART on the FMU?
nxf58541
Is there a way to check the UART on the FMU to see if it functioning correctly? I've tried everything (checked the baud, delt with RPi serial shenanigans, swaped Rx Tx wires, etc.) to hook up an RPi and just can't get an Rx signal on the FMU or RPi.
nxf58541
The serial (UART) port first must fully configured via parameters. Please check out this link: https://docs.px4.io/v1.9.0/en/peripherals/serial_configuration.html.
nxf58541
