variables got question mark when integrate with serial driver v3 for S12zVM
kelimagna
Hi there, I have some code working with freemaster serial driver v2. I am integrating the driver v3 from https://community.nxp.com/docs/DOC-345150. I still need to use poll mode but all the variables gave me question mark. The sci speed should be right, since I can make the connection. the freemaster_cfg.h was following the example in the package. I only removed TSA and PIPE. Are you able to help? Thanks, Ke
MichalH
NXP Apps Support
NXP Apps Support
Dear Ke,
I'm not sure what could be the issue here. Try to open the Tools/Communication Debug Log and select maximum verbosity of error messages. You should be able to see error codes being returned by the communication library.
You may also try a slightly updated driver version which supports both CodeWarrior and Cosmic S12Z tools. I have just updated the original post.
Let us know if there is any news.
Michal
MichalH
NXP Apps Support
NXP Apps Support
Dear Ke,
Michal
kelimagna
Hi Michal,
Thanks for your help. The issue is gone after integrating the new driver.
Ke Li
Sr. Software Engineering
Mechatronics
MAGNA
521 Newpark Blvd., P.O. Box 354 Stn. Main
Newmarket, Ontario L3Y 4X7 Canada
OFFICE 905-898-6744, ext. 2329
ke.li@magna.com<mailto:ke.li@magna.com>
