Low-power isolation config
Kazuma_Sasaki
Senior Contributor I
I am checking pad configuration settings for i.MX8DualX. I would like to know detail of low-power isolation setting.
From Community
System Controller Firmware 101 - Pad configuration service
From SCFW porting guide manual (sc_fw_port.pdf)
According to above descriptions, I can chose 4 settings(OFF/EARLY/LATE/ON).
What purpose should these settings be used?
How do these settings work?
Kazuma Sasaki.
Kazuma_Sasaki
I am getting answer from TIC.
all pad settings are described into following doc.
https://community.nxp.com/docs/DOC-344684
Kazuma Sasaki.
Kazuma_Sasaki
Kazuma Sasaki.
