HI :
now i have a problem, we want to make our can receive all ID meassages,so i want to use FIFO,but it does not work. i donot know how to use fifo. please help me
Solved! Go to Solution.
you can refer to below example for RXFIFO usage within SDK
https://community.nxp.com/docs/DOC-343091
But the RXFIFO itself does not help you to receive all IDs, matching is also done over RXFIFO ID filter table. If you want to receive all IDs you need to clear respective mask acceptance registers, so the receive ID is then don't care.
BR, Petr
BR, Petr
