How to set up ram in the MCU xpresso ide compilation environment
gaobiao315
hi all:
    Now I use McUxpresso IDE for debugging. The SRAM in MK21DN512AVMC5 chip has 64K, which is divided into 32K for SRAM_U and 32K for SRAM_L. Now my variables exceed 32K, how to allocate variables? Now the compiler prompts the following error:
Omar_Anguiano
Hello duan jz
I see that the error is caused because all the data is placed in Upper SRAM. To avoid this you can refer to this post: https://community.nxp.com/docs/DOC-335283
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
gaobiao315
希望各位大神,有时间帮助看一下,这边项目着急,谢谢了!
