AnsweredAssumed Answered
Help loading and running bin file via JLink
Question asked by Matthew Nunez on Feb 27, 2020
Latest reply on Feb 28, 2020 by igorpadykov
I am having difficulty running the ddr-test-uboot-jtag-mx6dq.bin on my custom board with 4 MT41K256M16HA-125 chips ganged off 1 CS line and each connected to 16bits of the DDR Data bus. I am using JLink commander to load the bin file via the attached jlink commander command file. The file has the copied ddr initialization commands from the helper script excel file. It is able to successfully load the bin file to memory at 0x00907000 and it verifies successfully. The wrinkle comes when I attempt to run it it with the go command. It does nothing. No change in the PC. If I step, runs the first couple instructions before becoming stuck.
Edit: The board is configured run from NOR flash at boot and has a program that is running from there on power up. I am halting the processor and doing all of this. I have also done a reset via jlink and entered all of the following instructions directly into JLink commander before loading the code with the same result.
Here is the output:
$ JLinkExe -device MCIMX6Q4 -if JTAG -speed 4000 -autoconnect 1 -CommandFile ./MX6Q_ARD_DDR3_register_programming_aid_v1.5.txt
SEGGER J-Link Commander V6.62c (Compiled Feb 21 2020 17:43:45)
DLL version V6.62c, compiled Feb 21 2020 17:43:30
J-Link Command File read successfully.
Processing script file...
Sleep(200)
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link compiled Jul 30 2008 11:24:37 ARM Rev.5
Hardware version: V5.30
S/N: 10007711
OEM: IARKS
VTref=3.300V
Target connection not established yet but required for command.
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Device "MCIMX6Q4" selected.
Connecting to target via JTAG
TotalIRLen = 13, IRPrint = 0x0101
WARNING: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
JTAG chain detection found 3 devices:
 #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
 #1 Id: 0x00000001, IRLen: ?, Unknown device
 #2 Id: 0x2191E01D, IRLen: ?, Unknown device
Scanning AP map to find all available APs
AP[3]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x44770001)
AP[1]: APB-AP (IDR: 0x24770002)
AP[2]: JTAG-AP (IDR: 0x14760010)
Iterating through AP map to find APB-AP to use
AP[0]: Skipped. Not an APB-AP
AP[1]: APB-AP found
ROMTbl[0][0]: CompAddr: 82141000 CID: B105900D, PID:04-003BB907 ETB
ROMTbl[0][1]: CompAddr: 82142000 CID: B105900D, PID:04-002BB906 CTI
ROMTbl[0][2]: CompAddr: 82143000 CID: B105900D, PID:04-004BB912 TPIU
ROMTbl[0][3]: CompAddr: 82144000 CID: B105900D, PID:04-001BB908 CSTF
ROMTbl[0][4]: CompAddr: 8214F000 CID: B105100D, PID:04-000BB4A9 ROM Table
ROMTbl[1][0]: CompAddr: 82150000 CID: B105900D, PID:04-000BBC09 Cortex-A9
Found Cortex-A9 r2p10
6 code breakpoints, 4 data breakpoints
Debug architecture ARMv7.0
Data endian: little
Main ID register: 0x412FC09A
I-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
D-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
System control register:
  Instruction endian: little
  Level-1 instruction cache enabled
  Level-1 data cache enabled
  MMU enabled
  Branch prediction enabled
Memory zones:
  [0]: Default (Default access mode)
  [1]: AHB-AP (AP0) (DMA like acc. in AP0 addr. space)
  [2]: APB-AP (AP1) (DMA like acc. in AP1 addr. space)
Cortex-A9 identified.
PC: (R15) = 33BFDB60, CPSR = 800001D7 (ABORT mode, ARM FIQ dis. IRQ dis.)
Current:
     R0 =80000000, R1 =00000000, R2 =0000001F, R3 =00000002
     R4 =C1646009, R5 =00000000, R6 =80000000, R7 =00000000
     R8 =00000001, R9 =00000000, R10=0000003E, R11=3B7057B8, R12=00000001
     R13=3B705754, R14=FFFFFFFF, SPSR=600001F7
USR: R8 =00000001, R9 =00000000, R10=0000003E, R11=3B7057B8, R12=00000001
     R13=3B702000, R14=00000000
FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11=00000000, R12=00000000
     R13=3B70A000, R14=00000000, SPSR=2D0A0178
IRQ: R13=3B707F1C, R14=20000117, SPSR=20000117
SVC: R13=3B6FF7B4, R14=33BD6794, SPSR=C0008084
ABT: R13=3B705754, R14=FFFFFFFF, SPSR=600001F7
UND: R13=3B704000, R14=00000000, SPSR=22005050
Writing 00000030 -> 020BC000
Writing FFFFFFFF -> 020C4068
Writing FFFFFFFF -> 020C406C
Writing FFFFFFFF -> 020C4070
Writing FFFFFFFF -> 020C4074
Writing FFFFFFFF -> 020C4078
Writing FFFFFFFF -> 020C407C
Writing FFFFFFFF -> 020C4080
Writing FFFFFFFF -> 020C4084
Writing 000C0000 -> 020E0798
Writing 00000000 -> 020E0758
Writing 00000030 -> 020E0588
Writing 00000030 -> 020E0594
Writing 00000030 -> 020E056C
Writing 00000030 -> 020E0578
Writing 00000030 -> 020E074C
Writing 00000030 -> 020E057C
Writing 00000000 -> 020E058C
Writing 00000030 -> 020E059C
Writing 00000030 -> 020E05A0
Writing 00000030 -> 020E078C
Writing 00020000 -> 020E0750
Writing 00000030 -> 020E05A8
Writing 00000030 -> 020E05B0
Writing 00000030 -> 020E0524
Writing 00000030 -> 020E051C
Writing 00000030 -> 020E0518
Writing 00000030 -> 020E050C
Writing 00000030 -> 020E05B8
Writing 00000030 -> 020E05C0
Writing 00018200 -> 020E0534
Writing 00008000 -> 020E0538
Writing 00018200 -> 020E053C
Writing 00018200 -> 020E0540
Writing 00018200 -> 020E0544
Writing 00018200 -> 020E0548
Writing 00018200 -> 020E054C
Writing 00018200 -> 020E0550
Writing 00020000 -> 020E0774
Writing 00000030 -> 020E0784
Writing 00000030 -> 020E0788
Writing 00000030 -> 020E0794
Writing 00000030 -> 020E079C
Writing 00000030 -> 020E07A0
Writing 00000030 -> 020E07A4
Writing 00000030 -> 020E07A8
Writing 00000030 -> 020E0748
Writing 00000030 -> 020E05AC
Writing 00000030 -> 020E05B4
Writing 00000030 -> 020E0528
Writing 00000030 -> 020E0520
Writing 00000030 -> 020E0514
Writing 00000030 -> 020E0510
Writing 00000030 -> 020E05BC
Writing 00000030 -> 020E05C4
Writing 00008000 -> 021B001C
Writing A1390003 -> 021B0800
Writing 001F001F -> 021B080C
Writing 001F001F -> 021B0810
Writing 001F001F -> 021B480C
Writing 001F001F -> 021B4810
Writing 43260335 -> 021B083C
Writing 031A030B -> 021B0840
Writing 4323033B -> 021B483C
Writing 0323026F -> 021B4840
Writing 483D4545 -> 021B0848
Writing 44433E48 -> 021B4848
Writing 41444840 -> 021B0850
Writing 4835483E -> 021B4850
Writing 33333333 -> 021B081C
Writing 33333333 -> 021B0820
Writing 33333333 -> 021B0824
Writing 33333333 -> 021B0828
Writing 33333333 -> 021B481C
Writing 33333333 -> 021B4820
Writing 33333333 -> 021B4824
Writing 33333333 -> 021B4828
Writing 00000800 -> 021B08B8
Writing 00000800 -> 021B48B8
Writing 00020036 -> 021B0004
Writing 09444040 -> 021B0008
Writing 8A8F7955 -> 021B000C
Writing FF328F64 -> 021B0010
Writing 01FF00DB -> 021B0014
Writing 00001740 -> 021B0018
Writing 00011740 -> 021B0018
Writing 000026D2 -> 021B002C
Writing 008F1023 -> 021B0030
Writing 00000047 -> 021B0040
Writing 841A0000 -> 021B0000
Writing 04088032 -> 021B001C
Writing 00008033 -> 021B001C
Writing 00048031 -> 021B001C
Writing 09408030 -> 021B001C
Writing 04008040 -> 021B001C
Writing 0408803A -> 021B001C
Writing 0000803B -> 021B001C
Writing 00048039 -> 021B001C
Writing 09408038 -> 021B001C
Writing 04008048 -> 021B001C
Writing 00005800 -> 021B0020
Writing 00011117 -> 021B0818
Writing 00011117 -> 021B4818
Writing 00025576 -> 021B0004
Writing 00011006 -> 021B0404
Writing 00000000 -> 021B001C
Downloading file [./../../ddr-test-uboot-jtag-mx6dq.bin]...
O.K.
Script processing completed.
J-Link>go
J-Link>halt
PC: (R15) = 00907000, CPSR = 800001D7 (ABORT mode, ARM FIQ dis. IRQ dis.)
Current:
J-Link>s
00907000:  18 F0 9F E5        LDR     PC, [PC, #+0x18]    ; 0x00907020
J-Link>s
00907174:  51 00 00 EB        BL      #+0x144             ; 0x009072C0
J-Link>s
009072C0:  FF 5F 2D E9        PUSH    {R0-R12,LR}
J-Link>s
J-Link>s
J-Link>s
J-Link>verifybin /Users/xxx/ddr_stress_tester_uboot_v3.00/ddr-test-uboot-jtag-mx6dq.bin 907000
Loading binary file /Users/xxx/ddr_stress_tester_uboot_v3.00/ddr-test-uboot-jtag-mx6dq.bin
Reading 121880 bytes data from target memory @ 0x00907000.
Verify successful.
Outcomes
