Error during debugging for Hexiwear using KDS
markjvillamor
Good evening,
I am currently programming Hexiwear using KDS. I followed the startup instructions carefully and I did not encounter any problems building the program at gitub. I then moved on to debugging and it was going smoothly at first before I encountered this error message. The debugger was loading up until 8% before having issues as seen in the image. Has any of you encountered and solved this problem?
Thank you.
Mark
soledad
Please check the following thread:
https://community.nxp.com/thread/506007
I hope this helps, have a nice day!
Soledad
