how to collect multichannel ADC voltage,by S32K118 and S32SDK
zhaowei961
I want to query the voltage measurement value of multi-channel regularly by means of interruption, how to realize this .
the CPU is S32K118 .thank you very much.Need help,
PetrS
the "adc_hwtrigger" SDK example is available in the S32DS. It configures PDB to trigger single ADC channel. You can modify it to add more pretriggers and such do multi channel conversion.
You can refer to https://community.nxp.com/docs/DOC-343295 how to do that.
BR, Petr
