Hello, I am going to carry out the sample production now, the chip used is MC9S12Z series, what tool should I use to download the xs file used in production.Many thanks!
NXP does not provide stand alone programmers.
the colleague of mine prepared a document: S12(X) Programming/Debugging Possibilities
There is paragraph describing stand alone possibilities. Simply, it directs you to Pemicro.com or Lauterbach.com.
If you do not want to invest any money and there is only a few parts to be programmed it is also good to think about using CodeWarrior.
Ladislav
