Install IAR Eclipse plug-in into S32 Design Studio for ARM
347996379
hello.
I want to use IAR compiler. so I install IAR Plugin manager that following this "HOWTO_Install_IAR_Eclipse_plugin_into_S32_Design_Studio_for_ARM.pdf"
But I encountered the following problem during installation.
After installation, I did check 'window->preferences'. but there is no 'IAR Embedded Workbench'
->I run IAR plugin manager (Menu "Help" -> "IAR Embedded Workbench plugin manager...") , can show the below info.
Note: I already installed IAR workbench in my laptop, the path is C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.4\,  the version is 8.42.1
-> after click the "Install" button into next step.
-> select all, and click the "Next"  button:
-> click the "Next"  button, problem is occurred, installation failed.
  • What is the problem? Could you help me analyze the reason?
Tags (2)
turgaykale
I am facing with the same problem, is there any solution ?
chaitanya_kalyani
I am also facing same issue. Have you find any solution for this.
