By following this explanation : S32K144 EVB and Lauterbach ,
on how to start Trace32 with S32DS.
It works well with the S32k142 evaluation board,
however when I use directly our PCB with the S32k142 MCU, S32DS opens Trace32,
but the elf file is not loaded. I am abble to load it manually with command:
-> flash.auto all
and by selecting the elf file.
It will be more convenient to load it automatically.
Do you have any idea to solve this issue.
Mohamed
