AnsweredAssumed Answered
S32DS ARM activation failed
Question asked by peisong lou on Nov 11, 2019
Latest reply on Nov 14, 2019 by Diana Batrlova
Hi, Support Team
i download S32DS ARM 1.3/2.0 and try to activate it, but it failed online and offline mode, i tried many times, but it still not work, below is the log file, could you help me solve this problem, thanks!
__________________________________________________________________________
Tue Nov 12 11:28:00 CST 2019
Free Memory: 18652 kB
Total Memory: 33656 kB
java.class.path:
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\IAClasses.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\Execute.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\InstallerData\Execute.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\Resource1.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\InstallerData\Resource1.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\resources.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\rt.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\sunrsasign.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jsse.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jce.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\charsets.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jfr.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\classes
java.ext.dirs:
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\ext
C:\Windows\Sun\Java\lib\ext
java.version == 1.8.0_51 (Java 1)
java.vm.name == Java HotSpot(TM) Client VM
java.vm.vendor == Oracle Corporation
java.vm.version == 25.51-b03
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 1.8
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 1.8
java.vendor == Oracle Corporation
java.vendor.url == http://java.oracle.com/
java.class.version == 52.0
java.library.path == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Lenovo\Access Connections\;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\ThinkPad\Bluetooth Software\;C:\Program Files\ThinkPad\Bluetooth Software\syswow64;C:\Program Files\MATLAB\R2019b\runtime\win64;C:\Program Files\MATLAB\R2019b\bin;C:\Program Files\MATLAB\R2017a\runtime\win64;C:\Program Files\MATLAB\R2017a\bin;C:\Program Files\MATLAB\R2019b\polyspace\bin;C:\Program Files\TortoiseSVN\bin;C:\Users\XH\AppData\Local\Programs\Python\Python36\Scripts\;C:\Users\XH\AppData\Local\Programs\Python\Python36\;.
java.compiler == null
java.home == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre
java.io.tmpdir == C:\Users\XH\AppData\Local\Temp\
os.name == Windows 7
os.arch == x86
os.version == 6.1
path.separator == ;
file.separator == \
file.encoding == GBK
user.name == XH
user.home == C:\Users\XH
user.dir == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows
user.language == en
user.region == null
Installed Feature(s) S32DSF of S32 Design Studio for ARM v2.0
Install Begin: NOVEMBER 11, 2019 9:48:33 PM CST
Install End: NOVEMBER 12, 2019 11:27:57 AM CST
Installed by InstallAnywhere 16.5 Professional Build 4860
User Interactions
#Choose additional feature(s)
CHOSEN_FEATURE_LIST=S32DSF
CHOSEN_INSTALL_FEATURE_LIST=S32DSF
CHOSEN_INSTALL_SET=S32 Des
#Choose Install Location
USER_INSTALL_DIR=C:\\NXP\\S32DS_ARM_v2.0
#Choose Shortcut Folder
USER_SHORTCUTS=C:\\Users\\XH\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\NXP S32 Design Studio\\S32 Design Studio for ARM v2.0
#Install
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\iawin32.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\win64_32_x64.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\remove.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\invoker.exe=Yes
Summary
Installation: Unsuccessful.
34 Successes
6 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space: C:\NXP\S32DS__v2.0
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space: 2,445,121,672; Free Disk Space: 44,791,119,872
Check Disk Space: C:\NXP\S32DS_ARM_v2.0
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Install JRE: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Install Directory: C:\Users\XH\AppData\Local\Temp\021245.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Execute Command: NET SESSION
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist.zip
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist2010.zip
Status: SUCCESSFUL
Execute Command: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe /quiet
Status: SUCCESSFUL
Execute Command: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe /quiet
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService\FNPLicensingService
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\install_fnp.sh
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\Activation.zip
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" install -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" verify -feature Activated -version 2.0 -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" run -feature Activated -version 2.0 -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" list
Status: SUCCESSFUL
Install Uninstaller: S32 Design Studio for ARM v2.0(Install All Uninstaller Components)
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\iawin32.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\win64_32_x64.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\remove.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\invoker.exe
Status: SUCCESSFUL
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe
Status: WARNING
Additional Notes: WARNING - The file does not exist
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService\FNPLicensingService
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\install_fnp.sh
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar
Status: WARNING
Uninstall Folder: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService
Status: WARNING
Additional Notes: WARNING - The path does not exist
Uninstall Folder: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Status: SUCCESSFUL
Remove Registry Entry: 5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name: Trigger Rollback Action
Action Description: Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
====================STDERR ENTRIES==================
InstallAnywhere 2014 SP1
Version: 16.5
Mon Nov 11 21:48:28 CST 2019
Free Memory: 10576 kB
Total Memory: 15872 kB
No Arguments
java.class.path:
ZGUtil.CLASS_PATH:
java.ext.dirs:
os.arch == x86
os.version == 6.1
path.separator == ;
file.separator == \
user.name == XH
user.language == zh
user.region == null
Loading externalized properties
RepositoryManager: Trying fallback repository location...
# INSTALLING VM: C:\NXP\S32DS_ARM_v2.0\jre
System's temporary directory = C:\Users\XH\AppData\Local\Temp
==== License service installation log start: ====
==== License service installation log end. ====
==== License activation log start: ====
CLLReason [errorNo=40, errorString=Error sending an activation request to a remote activation server and processing the resulting response. Failed to connect to the license server or Operations server. (FNP error 50041,41143,34), flxActMajorErrorNo=50041, flxActMinorErrorNo=41143, flxActSysErrorNo=34, flxCommErrorNo=0]
CLLReason [errorNo=34, errorString=Invalid offline response, ResponseType, flxActMajorErrorNo=0, flxActMinorErrorNo=0, flxActSysErrorNo=0, flxCommErrorNo=0]
No activation Id was entered
==== License activation log end. ====
==== License list start: ====
==== License list end. ====
XMLScriptWriter: No Installation Objects were skipped
8. final log file name=C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\Logs\S32_Design_Studio_for_ARM_v2.0_Install_11_12_2019_11_28_00.log
====================STDOUT ENTRIES==================
C:\NXP\S32DS_ARM_v2.0\jre\bin
C:\NXP\S32DS_ARM_v2.0\jre\bin\awt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\bci.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\client
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\classes.jsa
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\jvm.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\Xusage.txt
C:\NXP\S32DS_ARM_v2.0\jre\bin\dcpr.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\decora_sse.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\deploy.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin\deployJava1.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin\npdeployJava1.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dt_shmem.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dt_socket.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\eula.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\fontmanager.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\fxplugins.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\glass.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\glib-lite.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\gstreamer-lite.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\hprof.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\instrument.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\j2pcsc.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\j2pkcs11.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jaas_nt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jabswitch.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java-rmi.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\java.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\JavaAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javacpl.cpl
C:\NXP\S32DS_ARM_v2.0\jre\bin\javacpl.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_font.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_font_t2k.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_iio.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javaw.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\javaws.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java_crw_demo.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jawt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\JAWTAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jdwp.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfr.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfxmedia.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfxwebkit.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jjs.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\jli.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2iexp.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2launcher.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2native.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2ssv.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jpeg.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsdt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsound.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsoundds.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\kcms.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\keytool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\kinit.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\klist.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\ktab.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\lcms.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\management.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\mlib_image.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\msvcr100.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\net.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\nio.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\npt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\orbd.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\pack200.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2\msvcr100.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2\npjp2.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\policytool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_common.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_d3d.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_es2.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_sw.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\resource.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\rmid.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\rmiregistry.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\servertool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\splashscreen.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\ssv.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\ssvagent.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\sunec.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\sunmscapi.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\t2k.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\tnameserv.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\unpack.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\unpack200.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\verify.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\w2k_lsa_auth.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\WindowsAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\wsdetect.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\zip.dll
C:\NXP\S32DS_ARM_v2.0\jre\COPYRIGHT
C:\NXP\S32DS_ARM_v2.0\jre\lib
C:\NXP\S32DS_ARM_v2.0\jre\lib\accessibility.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\calendars.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\charsets.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\classlist
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\CIEXYZ.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\GRAY.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\LINEAR_RGB.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\PYCC.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\sRGB.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\content-types.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\currency.data
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\ffjcext.zip
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_de.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_es.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_fr.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_it.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_ja.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_ko.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_pt_BR.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_sv.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_CN.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_HK.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_TW.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\access-bridge.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\cldrdata.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\dnsns.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\jaccess.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\jfxrt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\localedata.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\meta-index
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\nashorn.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunec.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunjce_provider.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunmscapi.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunpkcs11.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\zipfs.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\flavormap.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\fontconfig.bfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\fontconfig.properties.src
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightDemiBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightDemiItalic.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightItalic.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaSansDemiBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaSansRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaTypewriterBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaTypewriterRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\hijrah-config-umalqura.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\i386
C:\NXP\S32DS_ARM_v2.0\jre\lib\i386\jvm.cfg
C:\NXP\S32DS_ARM_v2.0\jre\lib\images
C:\NXP\S32DS_ARM_v2.0\jre\lib\images\cursors
C:\NXP\S32DS_ARM_v2.0\jre\lib\images\cursors\cursors.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\javafx.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\javaws.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jce.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr\default.jfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr\profile.jfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfxswt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jsse.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jvm.hprof.txt
C:\NXP\S32DS_ARM_v2.0\jre\lib\logging.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\management
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\jmxremote.access
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\jmxremote.password.template
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\management.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\snmp.acl.template
C:\NXP\S32DS_ARM_v2.0\jre\lib\management-agent.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\meta-index
C:\NXP\S32DS_ARM_v2.0\jre\lib\net.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\plugin.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\psfont.properties.ja
C:\NXP\S32DS_ARM_v2.0\jre\lib\psfontj2d.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\resources.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\rt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\security
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\blacklist
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\blacklisted.certs
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\cacerts
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\java.policy
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\java.security
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\javaws.policy
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\local_policy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\trusted.libraries
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\US_export_policy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\sound.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\tzdb.dat
C:\NXP\S32DS_ARM_v2.0\jre\lib\tzmappings
C:\NXP\S32DS_ARM_v2.0\jre\LICENSE
C:\NXP\S32DS_ARM_v2.0\jre\README.txt
C:\NXP\S32DS_ARM_v2.0\jre\release
C:\NXP\S32DS_ARM_v2.0\jre\THIRDPARTYLICENSEREADME-JAVAFX.txt
C:\NXP\S32DS_ARM_v2.0\jre\THIRDPARTYLICENSEREADME.txt
C:\NXP\S32DS_ARM_v2.0\jre\Welcome.html
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\.com.zerog.registry.xml
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\InstallScript.iap_xml
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\uninstaller.jar
Outcomes
