When I configure can in the NXP Model-Based Design Tools, I download the model to the 5744P development board. If I don't connect the can device or start the can device at the beginning, then connect and open the can device after the MCU is running. I will not receive Can signal, but I can receive the can signal after resetting the development board. Is there any way to solve this problem?
Thank you for your interest in my question!Marius-lucian Andrei
Hello li jiantao,
Which MPC5744P dev board are you using, is it RevE or the previous one?
Marius
