AnsweredAssumed Answered
User Pin/Signal Name usage
Question asked by michaellüthold on Oct 10, 2019
Latest reply on Oct 14, 2019 by michaellüthold
Hello together
I just started to use S32 Design Studio. First I tried to enable an LED by a Switch.
This worked well so far. I always used the Pin number to use the driver functions. But I want to use user name of the Signal instead of the numbers. So I found the option "User Pin/Signal Name"
I filled in a desired name there, but I was not able to use this name. It always showed "LED_B undeclared..." during building.
So how can I use this user Pin name?
User Pin/Signal Name Setting
Outcomes
