I have a PE debugger and MPC5748G evaluation board and got a elf file about autosar from Davinci Configuration tool .
I want to debug my elf file on MPC5748G platform but I don't know using S32DS to debug without building relevant project is possible or not.
If it is possible ,how to implement? if not what means can I use?
Can you help me? Thank you.
Hi, here there is a described a procedure how to do it:
Hi:
I have followed the first method,but console indicate
"MPC574xG Device detected.
No breakpoints currently set.
Disconnected from "127.0.0.1" via 127.0.0.1
Target Disconnected.
Target Disconnected."
Is it successe or not?
Have your code been downloaded to the MCU?
