Hi Yuri,
This query is regarding IMX6UL, G2 version. What is the value written at production to TAMPER_PIN_DISABLE bits of Bank 0, Word 3 of the fuse map?
I have a virgin board and the tamper pins are disabled = 11, i.e. tamper pins 0 to 9 can be used as GPIOs. I am aware I can change the configuration of the pins on this version. However, is it safe to assume that 11 will be the default factory setting from NXP on G2 versions?
