Hello pgo,
I have a task where I need to use the USBDM applications, specifically FirmwareChanger and JS16_Bootloader in console mode. Unfortunately, I discovered that these applications do not support execution of its functions from the command line. The console mode is particularly useful for automating test procedures.
Is there a reason these applications were not designed to enable both GUI and console mode? As I also understand, the UsbdmFlashProgrammer application does not have this drawback.
Cyril.
I did not anticipate the need to run these in console mode. Reprogramming the BDM is an infrequent event (at least that is what I thought).
Another contributor (Tom Hebb) has added console mode for JS16 bootloader. This will be incorporated in the next release.
bye
