download separate elf file to microcontroller using S32 Design Studio
zengqi300
Background:
    I met trouble during  executing as
HOWTO: download separate elf/srec/hex file to microcontroller using S32 Design Studio
steps 。
Console fault message as follows:
“ MPC574xG Device detected.  No breakpoints currently set.  Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "16572" from 7224 Target Disconnected. ”
Whether the elf  os is influential? My  elf file os is MicroSA which from vector。
Tags (2)
jiri_kral
can you please share your elf file? If it is compiled for MPC5748G - it should work.
Jiri
zengqi300
