Can anybody advise as to why Single Step functions step-into and step-over both perform the same step-into function. Am I missing some setting somewhere?
We're using our own project and its optimized code, is that the problem?
yes, in some cases it may be an issue. For debugging purposes is better solution use non-optimized code.
Jiri
can you provide more details like screenshots? Are you using some example or your own project? Did you enabled optimizations?
Jiri
