I want to auto run a custom script during start up
I am using i.mx8mmini board yocto
building using bitbake fsl-image-validation-imx
Santhosh
Solved! Go to Solution.
Hi Santhosh Kumar,
Please check below thread:
[Yocto] Auto run script when startup
Let us know if above thread do not solve your problem.
Karan Gajjar
Hi Santhosh Kumar,
If your system has /etc/inittab, try adding a line in it.
What the Linux /etc/inittab file tells your system to do | Network World
Karan Gajjar
Hi Karan,
inittab is not found in my rfs, I tried as per this link also cron - Running command at startup on crontab - Ask Ubuntu
I placed the command sudo sh /home/root/startupscript.sh in /etc/rc.local
before the exit 0
line
But things didn't work. it didn't execute the startupscript at all
Any other alternative..
Thanks Issue resolved... :smileyhappy:
edited the /etc/rc.local file and added the below line before the exit(0)
cd /home/root/
sh startupscript.sh
Santhosh Kumar S
