How to add custom system service to AOSP
msingh1920
Hi Sir,
I am new to iMX and Android AOSP world and studying the Android System.
I am using iMX8m mini board and i am able to download and build AOSP for Android 9 for this board.
Now i want to add simple custom system service to this AOSP but i don't know how to do this.
I followed the discussion -
https://community.nxp.com/message/606552?commentID=606552#comment-606552
and checked the below link which he was mentioning -
shridutt kothari's blog: Adding New System Service in Android
Android-Adding SystemService - Texas Instruments Wiki
I also checked this link -
AOSP – Creating a System Service – Developers Area
But it seems link these steps are for older Android versions. And I am using Android 9.
Please suggest me how can add a simple system service for Android 9 and for my iMX8m Mini board.
Thanks & Regards,
Maneesh
msingh1920
Hi Diego Adrian Cuevas, and Team NXP,
As I mentioned in my original question [ here ] what all changes and steps I did to add a custom service in Android 9.0 AOSP
I am referring below links for Adding custom service in AOSP but unfortunately they are very old and using AOSP 5 or 6 or 8 version.
I am using AOSP Android 9.0 version and NXP iMX8M Mini EVK board.
Links which i am referring =>
This is based on AOSP 6 version
http://haohaochang.cn/2017/10/27/custom-android-system-service/
This is based on AOSP 8 version
https://devarea.com/aosp-creating-a-system-service/#.XXIA1XUzY8o
In all the above link I found that for AOSP Version 6 files and directories mentioned to add selinux policy for custom service is completely different
and not present in AOSP version 9. And files and directories mentioned in AOSP 8 is matching with AOSP 9 but few files are missing in AOSP 9 version.
My Observation -
With All the changes I am able to rebuild the AOSP and I am able to see my App but when i try to access my custom service from my app then it is failed to discover / get my system service. it means My system service is not running or not discoverable to my app.
Please suggest me -
1) Apart from above mentioned steps [ here ] which i performed,  is there any other steps which I need to did for my custom service in AOSP ?
2) Steps to add SE Linux Permissions for custom service for Android 9.0 AOSP.
Thanks & Regards,
Maneesh Singh
msingh1920
For Adding a system service i did following steps -
NOTE - I am trying to add my own system service named - gea to AOSP Android 9 framework.
Adding system services to AOSP framework
        System Services
    1. Copy GeaService.java to
       AOSP frameworks/base/services/core/java/com/android/server of your AOSP
GeaService.java
package com.android.server;
import android.content.Context;
import android.os.Handler;
import android.os.IGeaService;;
import android.os.Looper;
import android.os.Message;
import android.os.Process;
import android.util.Log;
public class GeaService extends IGeaService.Stub {
    private static final String TAG = "GeaService";
    private Context mContext;
    private long mNativePointer;
    private int mValue = 0;
    public GeaService(Context context) {
    super();
    mContext = context;
    Log.i(TAG, "System service initialized");
    mNativePointer = init_native();
    Log.i(TAG, "test() returns " + test_native(mNativePointer, 20));
    write("HelloFromGEAService");
    Log.i(TAG, "read() returns " + read(50));
    protected void finalize() throws Throwable {
        finalize_native(mNativePointer);
        super.finalize();
    public String read(int maxLength)
    int length;
    byte[] buffer = new byte[maxLength];
    length = read_native(mNativePointer, buffer);
    return new String(buffer, 0, length);
    public int write(String mString)
    byte[] buffer = mString.getBytes();
    return write_native(mNativePointer, buffer);
    private static native long init_native();
    private static native void finalize_native(long ptr);
    private static native int read_native(long ptr, byte[] buffer);
    private static native int write_native(long ptr, byte[] buffer);
    private static native int test_native(long ptr, int value);
    public void test(int val) {
        Log.i(TAG, "test " + val);
        mValue = val;
    2. Add below lines in
       AOSP frameworks/base/services/java/com/android/server/SystemServer.java
      import com.android.server.GeaService;
      import android.os.GeaManager;
           try {
               Slog.i(TAG, "GEA Service");
               ServiceManager.addService(Context.GEA_SERVICE, new GeaService(context));
           } catch (Throwable e) {
               Slog.e(TAG, "Failure starting Gea Service", e);
    3. Copy IGeaService.aidl to
       AOSP frameworks/base/core/java/android/os/
     package android.os;
* {@hide}
interface IGeaService {
String read(int maxLength);
int write(String mString);
void test(int val);
    4. Copy GeaManager.java to
    package android.os;
public class GeaManager
    IGeaService mService;
    private static final String TAG = "GeaManager"; // this is for Log only..
    public String read(int maxLength) {
    try {
        return mService.read(maxLength);
    } catch (RemoteException e) {
        Log.e(TAG, "Excpetion in read: " + e.toString());
        return null;
    public int write(String mString) {
    try {
        return mService.write(mString);
    Log.e(TAG, "Excpetion in write: " + e.toString());
        return 0;
    try {
        mService.test(val);
        return;
    Log.e(TAG, "Excpetion in test: " + e.toString());
        return;
    public GeaManager(IGeaService service) {
        mService = service;
        5. Add below line to -> AOSP framework/base/Android.bp
                   "core/java/android/os/IGeaService.aidl",
    6. Add below lines to AOSP frameworks/base/core/java/android/app/SystemServiceRegistry.java
          registerService(Context.GEA_SERVICE, GeaManager.class,
                new CachedServiceFetcher<GeaManager>() {
            @Override
            public GeaManager createService(ContextImpl ctx) throws ServiceNotFoundException {
                IBinder b = ServiceManager.getServiceOrThrow(Context.GEA_SERVICE);
                IGeaService service = IGeaService.Stub.asInterface(b);
                return new GeaManager(service);
    7. Add below lines to AOSP frameworks/base/core/java/android/app/ContextImpl.java
    8. Add below lines to AOSP frameworks/base/core/java/android/content/Context.java
     * Use with {@link #getSystemService} to retrieve a
     * {@link android.os.GeaManager} for using Gea Service.
     * @see #getSystemService
    public static final String GEA_SERVICE = "gea";
But In my Android App (This App I am building inside AOSP / package / app ) when I try to get this
system service i always get toast msg - "FAILED to call system service".
package com.gea.hellointernal;
import android.app.Activity;
import android.os.Bundle;
import android.widget.Toast;
import android.os.ServiceManager;   // Will only work in AOSP
import android.os.IGeaService;      // Interface "hidden" in SDK
public class HelloGeaInternalActivity extends Activity {
    private static final String DTAG = "HelloGeaInternal";
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
        IGeaService om = IGeaService.Stub.asInterface(ServiceManager.getService("gea"));
         try {
            Log.d(DTAG, "Going to write to the \"gea\" service");
                int ret = om.write("Hello World!");
                Log.d(DTAG, "GEAManager.read returned: " + om.read(20) + " ret = " + ret);
            Toast.makeText(getApplicationContext(),"Going to write to the service",Toast.LENGTH_LONG).show();
        catch (Exception e) {
                Log.d(DTAG, "FAILED to call service : " + e.toString());
                  Toast.makeText(getApplicationContext(),"FAILED to call system service : "+e.getMessage(),Toast.LENGTH_LONG).show();
            e.printStackTrace();
NOTE - With All the changes I am able to rebuild the AOSP and I am able to see my App but when i open the App i always see
              FAILED to call system service toast msg... it means My system service is not working  or not discoverable to my app.
I am not understanding what I am missing or what changes i need to do to make my system service available in my app.
Any help or suggestion for what wrong I am doing here or how can i write simple custom system service and test it for Android 9 framework.
Note - I am using iMX8M Mini EVK and Android AOSP 9
Thanks & Regards,
Maneesh
nxf55348
maneeshsingh‌ Hi Maneesh Singh ,my computer has no memory to install the Android Studio, so I can’t make the apk base on your files, can you give me the apk ?
nxf55348
maneeshsingh Can you get me your Android APP and  the source code ,thanks.
msingh1920
Hi Yangyang Xuan,
Thanks for your reply.
PFA my AOSP App Link -
Link - AOSP_APP
Maneesh
nxf55348
maneeshsingh‌ ,Can you just get me the apk ,Thanks
diegoadrian
I have found the below information. Probably it can be helpful to you.
https://devarea.com/aosp-creating-a-system-service/#.XUC7KehKiUk
https://developer.android.com/guide/components/services
There you can see that is not only adding the java service, it is also needed to be done other things.
Hope this information can help you.
Diego.
msingh1920
I checked the Link you have provided and as you can see in my post above i have listed all the steps and changes which i did for system services.
i didn't did any changes for selinux as i am not sure how this will work.
please check my steps above and let me know what i am missing except selinux changes.
Also for Android 9 which i am using selinux has 28.0 directory instead of 26.0 directory as mentioned in the link you have provided.
Thanks & Regards,
Maneesh
