Can i used relative Humidity/temperature/pressure Sensor related Cluster on same EP?
Hi Vishal,
Yes, you can use in the same EndPoint. This is part of the application so, also it will depend on the cluster that you are reading/writing information.
https://community.nxp.com/docs/DOC-335075
Mario
Hi Vishal,
Mario
