Hi paulvlase,
another problem occured. After setting up on another PC everything except the PIL works. I get the following error
I am using the same model, Matlabversion and DevBoard as before.
I will attach the slprj and the diagnostics output.
I guess it has to do with the location of files again? I have installed Matlab in D instead C on this PC could that be the cause?
Thank you for your help
Paul
Hi pbgemann001@ikasle.ehu.eus,
Sorry for answering so late, but we were working on MBDT for S32K 4.0.1 release.
Right now the PIL is not working using the GCC compiler, somehow the application crashes on the board. I mentioned that here https://community.nxp.com/message/1145564#comment-1162694 .
I will try to fix this issue the next week.
Can you try to run PIL simulation using the IAR compiler?
