Hi,I want to change the ptn3460 LVDS panel control function, as described in the specification “PVCCEN pin -- the signal output is set based on SET_POWER DPCD register 00600h”。How do I modify DPCD registers values?
Hello kang keqin,
I’ll like to redirect you to this community thread https://community.nxp.com/message/855745 where you can find further documentation on the PTN3460, including the programming guide (AN11128) for the same.
I hope this information can be helpful.
Paulina
