Which registers need to be modified to set duty cycle and frequency in OPWMB in MPC5748G
Hello akhileshvernekar30@gmail.com,
If you want to find out more about the registers, please read the Chapter 35 from the Reference Manual.
Also, you can use the S32 SDK for PA, which provides support for controlling peripherals on MPC5748G.
Hope this helps,
Marius
Are we talking about the Model-Based Design Toolbox for MPC57xx? Do you generate your code from Simulink or you are using the S32DS for PA?
Marius
Sir we are writing a driver code for PWM so we need the registers which
could help to change duty cycle and frequency in MPC5748G
On Wed, 12 Jun 2019, 1:00 pm Marius Lucian Andrei, <admin@community.nxp.com>
Sir we want to write driver code for PWM.So which registers should be modified to set duty cycle and frequency
