Unable to flash MK20DN512VLL10 device
jes1
Hi there,
I am trying to flash firmware into a blank MK20DN512VLL10 device using the JLink command tool through the SWD interface.
I am unable to unlock or connect to the device. Attach is a screen shot of the output from the JLink tool.
Does the reset line of the device needs to be held high/low while being powered up. Any help with commands I should execute to get this going will be much appreciated.
jingpan
Hi Jes,
Many people faced similar problem like yours. I think their experience may help you.
MKL04Z8XXX4 Custom board lock/brick
Cannot halt S32K118EVB
https://community.nxp.com/message/1032875
Jing
