LPC 54018 Debug Issue
yashbohra80
I am trying to program LPC 54018 IOT Module using MCU IDE using PE Micro but when I try to debug a sample LED Blinky program,I get an error message saying that error in FLASH PROGRAM . terminate debug session.
In getting started session i checked i need to update qc firmware file , but while trying to do so I am not able to find qc firmware update file in SDK Version 2.5
ZhangJennie
Hi yash bohra
Not sure if I correctly understand your questions. Do you mean your IDE debugger can't launch debugger?
If so, you can try update on board debug firmware with referring this thread.
LPC54608 board doesnt see any debug probes
Jun Zhang
ZhangJennie
Hi yash bohra
Jun Zhang
yashbohra80
Hi ,
Thank you for your response. It is working now, there was some problem with USB.
ZhangJennie
You are welcome.
