How to get information of Motorola-S format?
I find some information about the file,like :
https://www.fujitsu.com/downloads/MICRO/fma/mcu/PCW16LXe.pdf
But I wish to find more detail about S0-S9,how many bytes use to save length,address,SUM,and so on.
Solved! Go to Solution.
Do these cover you?
SREC (file format) - Wikipedia
File:Motorola SREC Chart.png - Wikipedia
Also, check this thread: S19 and SX Files...
One more reference in A-1 (appendix) of this manual: https://www.nxp.com/docs/en/user-guide/M68HC705JICSUM.pdf
Do these cover you?
Thank you verymuch. It is useful.
I am looking for the origin about the Wiki,and I will cite the Wiki and the document as follow if fail.
However,I found this document from the Wiki:
https://www.nxp.com/files-static/archives/doc/ref_manual/M68000PRM.pdf
And try to find other origin.
