delay unit for DQ setting in MMDC register for i.MX6
ko-hey
Senior Contributor II
Hi all,
I have question about delay unit in MMDC register.
Could you tell me the delay unit period ?
According to the description of MMDCx_MPRDDQBY0DL in IMX6DQRM, it shows the delay as below.
010         Add dq0 delay of 2 delay units.
011         Add dq0 delay of 3 delay units.
Does above period is same as following thread ?
https://community.nxp.com/message/483747
The thread said that 1 delay unit is 2-3[ps].
Does the delay unit which is described in MMDCx_MPRDDQBY0DL same ?
Ko-hey
Labels (2)
Yuri
  typical delays are  on the order of picoseconds.
“Q&A: Delay units in SDCLKx_DEL of MMDCx_MPSDCTRL register”
https://community.nxp.com/docs/DOC-95580
Yuri.
