Interfacing higher datarate DDR3 with i.MX6
santhiya_rssl
Interfacing DDR3 memory having higher data rate with i.MX6ULZ.
With reference to the attached data from i.MX6 ULZ datasheet- DDR3 supports upto 400MHz clock rate with single channel.
Kindly confirm whether this can be down converted from the memory side for the below mentioned parts
Micron -- MT41J128M16JT-093:K TR
Windbond -- W632GG6MB-12 TR
Rita_Wang
And use the i.MX6ULL_DDR3_Script_Aid to configure DDR3.
Rita_Wang
You can refer to the reference board DDR design https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true .
