Hi NXP Team,
I am using yocto build and I want to implement example base on openMax for h264 video decoding. I found sample test code in file "openmax_il/source/decoder/test/video_decoder.c" but this code is not compiling.
Can any one help me to compile this code or give any other reference example that can compile and i can test it ?
Jignesh Patel
it seems you need to set the environment , you can refer the topic as below:
