imx8q userdata.img flash into emmc
mengqicheng
Following How to enable userdata.img and cache.img in lollipop , I success create userdata.img, but launched failed after  flashing.
Question 1:  userdata partition size is auto("grow": true) in 'device-partitions-28GB-dualos-ab.bpt',  correct?
Question 2: Is script blow in 'uuu-dualos-mx8qm-mek-emmc.lst' correct?
FB: flash userdata  userdata.img
Rita_Wang
Which version BSP are you using?
