Vilém Kužel
NXP Rapid IoT and Sigfox - Sigfox ID discovery
Discussion created by Vilém Kužel on Jan 30, 2019
Having a new new Sigfox click module you have to know its Sigfox ID in order to be able to register your new device. This example alows you to retrieve the Sigfox ID, print it out to serial port and show it directly on the display (=no need to launch serial monitor).
It expects you have the following equipment:
NXP Rapid IoT Development Kit in Hexiwear docking station with Sigfox module
Once is the firmware uploaded to your NXP Rapid IoT, just touch right touch area or press right up button:
NXP Rapid IoT Development Kit is ready to retrieve Sigfox ID
Uyou should get your Sigfox ID id a short time:
NXP Rapid IoT Development Kit displays retrieved Sigfox ID
The Sigfox ID is dispalyed on NXP Rapid IoT Development Kit display as well as printed out to the debug output.
You can easily modify the script to discover the Sigfox PAC.
Outcomes
