1.
Hi , I am currently using MPC5748G-LCEVB board to develop our products, but when I am reading the MPC5748G-LCEVB_QSG, I found I can't visit the link below
which displys:
Without these examples or docs, I found it very hard to carry on!
2.
And It didn't work out when I follow the link below step by step to
HOWTO: download separate elf/srec/hex file to microcontroller using S32 Design Studio
Does that require something else configuration that it does not mention?
I fellow the steps with s32 power v1.2 every time only to find the warning poped up to saying :
and it will stay where it is forever
Is there anybody can help me out of this?
Thanks very much!
for downloading examples, please try to use link below:
https://www.nxp.com/downloads/en/board-support-packages/MPC5748G-LCEVB_QSP.zip
About the problem with pop-up window, have you switch the board off and on again and clicked OK? What happened next?
Could you please check your board power supply is correct?
What debug probe you use to download the code into the microcontroller?
Martin
