Unable to use UHS SDcard in imx6
balasubramaniyam
I am usig i.MX6 Processor with customize board which can support Ultra High Speed SDcard in USDHC2.
UHS-I tested in L4.9.11 kernel with Poky-Morty binaries.
supporting SDR104 in imx6 board by yocto
From the above link I made the changes in device tree to support Ultra High Speed, but while booting SDcard failed in initialising and USDHC2 got CMD timeout error.
Changes:
&usdhc2 {
     pinctrl-names = "default", "state_100mhz", "state_200mhz";
     pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
     pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
     pinctrl-2 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
     cd-gpios = <&gpio4 25 GPIO_ACTIVE_LOW>;
     vmmc-supply = <&reg_sd2_vmmc>;
     keep-power-in-suspend;
     /* no-1-8-v; */
     enable-sdio-wakeup;
     status = "okay";
reg_sd2_vmmc: regulator@6 {
    compatible = "regulator-fixed";
     regulator-name = "P3V3_SDa_SWITCHED";
     regulator-min-microvolt = <3300000>;
     regulator-max-microvolt = <3300000>;
     /* GPIO to toggle 3.3V and 1.8V to SDcard */
     gpio = <&gpio6 11 GPIO_ACTIVE_HIGH>;
     enable-active-high;
     off-on-delay = <20000>;
pinctrl_usdhc2: usdhc2grp {
     fsl,pins = <
     MX6QDL_PAD_SD2_CMD__SD2_CMD 0x1F079
     MX6QDL_PAD_SD2_CLK__SD2_CLK 0x1F079
     MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x1F079
     MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x1F079
    MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x1F079
     MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x1F079
pinctrl_usdhc2_100mhz: usdhc2grp_100mhz {
     fsl,pins = <
pinctrl_usdhc2_200mhz: usdhc2grp_200mhz {
     fsl,pins = <
pinctrl_usdhc2_gpio: usdhc2_gpiogrp {
     fsl,pins = <
     MX6QDL_PAD_NANDF_CS0__GPIO6_IO11 0x1F088 /* PDn */
Error log:
 sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
 sdhci-esdhc-imx 2194000.usdhc: change pinctrl state for uhs 0
 mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
 mmc1: error -110 whilst initialising SD card
Did I miss any entry in device tree to support Ultra high speed mode or anything?
Hoping for the better guidance.
Thanks and Regards,
Bala
Tags (4)
balasubramaniyam
We have no trouble to use UHS-I SD cards in High-Speed mode without any changes.
But once we enable 1.8V support in the device tree for Ultra-High-Speed mode the SDcard get failed in initializing and even it is not fallback to work in High-Speed mode.
And we removed pullups on the data and command lines in SDcard to test the UHS-I but the errors remain same.
joanxie
what board and bsp do you use? as I known, the latest bsp supports sd3.0 as default already, you don't change any bsp
balasubramaniyam
Hi Joan Xie,
I am using our customize board.
From which BSP release SD3.0 is supported?
Bala
joanxie
4.9.11 should support it, but you can try to use the newer version 4.9.88 without change
balasubramaniyam
Tested in Linux 4.9.88 kernel still behavior is same and SDcard is not working in ultra-high-speed mode.
joanxie
what board do you use? imx6Q board?
balasubramaniyam
imx6QP(QuadPLUS) board
jianhua_zhuang
can you share how to fix it?
