Hi all,
I am working on IMX7 Dual SABRE board. I want to debug Cortex-M4 core through JTAG in IAR workbench. I tried with I-JET and PE-Micro debugger but I am not able to flash.
What are the steps I need to follow if I want to debug it through JTAG?
Any settings or configuration I need to do on the board or in IAR.
Please help...
Thanks and Regards,
Ravi Ranjan Kumar.
Hi Ravi
one can look at
Debugging Cortex-M4 on i.MX7D with Segger J-Link and GDB (and thus standard Eclipse)
https://www.embeddedartists.com/sites/default/files/support/com/iMX7_Working_with_Cortex-M4.pdf
AN5229 ARM DS-5 Development Studio Debug i.MX6UL-EVK
https://www.nxp.com/docs/en/application-note/AN5229.pdf
Hi, igorpadykov,
Thanks for your valuable information. I have gone through those documents, there is not enough information for IAR. In some documents, it is given that create a bin file and upload (It is working fine). But can I debug it directly in Keil or IAR using PE-Micro or I-Jet?
I am using VCC, TMS, TCK, nRES, GND pin in JTAG, is it correct?
Please guide...
Thanks and regard,
Ravi Ranjan Kumar.
Hi Ravi
for using these debug tools suggest to contact its vendor tech support:
PE-Micro
PEmicro | Experts in Embedded tools for Flash Programming and Development
Keil
