In datasheet https://www.nxp.com/docs/en/data-sheet/MC33907-MC33908D2.pdf I don't find any AEC-Q100 information about the part, also not in any other documents related to that part, although it supposed to be dedicated to the automotive market. Where can I find that info?
Solved! Go to Solution.
Qualification information is found typically in the PPAP or the qualification paperwork. - best resource is to request information from the quality department.
for instance this was in a recent notification
This is from notification 2017110021 customer notification
PWRSBC_LIN Design Change (see attached)
Hi Marijan,
What kind of information are you looking for?
Kindly note the Safety Manual is available per request. But in case you are looking for the FMEDA or the Confirmation Measure Report, you will have to ask access to our NDA SafeAssure space.
I am looking for a document, where it will be clearly written like this:
"Automotive product qualification in accordance with AEC-Q100"
