How to burn NandFlash from SDcard on i.MX6UL
jackjiang
Dears,
How to burn NandFlash(or other memory) from SDcard on i.MX6UL?
I have look at fsl-yocto-L4.1.15_2.0.0-ga's<i.MX_Linux_User's_Guide>, no results.
Is there a solution to the problem?
Hi Jack
one can look at nand programming script for mfg tool on below link and try
to reuse ucl2.xml commands in linux running from sd card.
Mfg tools runs small linux image and executes linux commands from ucl2.xml file.
How-To use NAND boot on i.MX6UL EVK board
jackjiang
Thanks Igor,
I think you misunderstood me, I want to know how to use the SD card burn image to other memory(not only nand) for mass production.
Hi Jack
ok, then could you clarify meaning "how to use the SD card burn image to
other memory(not only nand) for mass production."
Mfg Tool is only tool provided by NXP for mass production purposes.
