JD Sun
Programming flash while running code from flash
Discussion created by JD Sun on Jul 10, 2018
Latest reply on Jul 12, 2018 by JD Sun
Hi, I use S32DS environment debugging TRK - KEA128 board Flash function, normal in debug mode can erase and write, but can't erase and write in normal mode, need to be copied into ram to run the program?
Outcomes
