GHS compiler and S32 Design Studio for Arm 2018.R1
seonho_hong
hello,
now I'm trying to make a project with S32 Design Studio with below environment.
- MCU: S32k 146
-Compiler: Greenhils v2017.1.4
but I could not find the compiler setting on S32 Design Studio, only I could make a GCC project.
Do I need to install the plug-in for that? If yes, where can I find the material?
jiri_kral
please check this thread GHS plug-in can NOT successfully installed in S32DS for Power Architecture version 2017.R1
You can contact Green Hills support to obtain toolchain plugin compatible with Eclipse Neon version (S32DS is based on Eclipse Neon).
Hope it helps.
Jiri
