We have tried to use IMX6QuadPlus with two framebuffers (fb0 : background and fb1 :overlay) with the resolution 1080p@60Hz but we have some errors :
imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_10 = 0x00080000
imx-ipuv3 2800000.ipu: IDMAC21's U offset is not 8-byte aligned
imx-ipuv3 2800000.ipu: IDMAC21's V offset is not 8-byte aligned
imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x08800000
imx-ipuv3 2400000.ipu: warning: wait for bg sync eof timeout
When we use only one buffer we have no problem or if we use 720p@60Hz we can use two framebuffers
After to ask to our experts on imx6, they have done some tests and they say the imx6 have a bottleneck bandwith memory. We decide to use only one buffer and do the overlay with the GPU but we have a MMU error. See the dump, we have a DMA appears to be stuck at this address.
*** MMU ERROR DUMP ***
MMU status = 0x00000002
MMU0: page not present
MMU0: exception address = 0xCF300000
MTLB entry = 828
STLB entry = 768
Offset = 0x00000000 (0)
Page table entry = 0x00000002
GPU[8](ChipModel=0x320 ChipRevision=0x5303):
*** GPU STATE DUMP ***
axi = 0x00000080
idle = 0x7FFFFFF8
FE not idle
DE not idle
PE not idle
DMA appears to be stuck at this address:
0xFA5CC2A0
dmaLow = 0x48000000
dmaHigh = 0x00000701
dmaState = 0x00000815
command state = 21 (PAR_STALL_ST)
command DMA state = 0 (CMD_IDLE_ST)
command fetch state = 2 (FET_VALID_ST)
DMA request state = 0 (REQ_IDLE_ST)
cal state = 0 (CAL_IDLE_ST)
VE request state = 0 (VER_IDLE_ST)
Debug registers:
RA[0] debug registers:
[00] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[08] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[10] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[18] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[20] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[28] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[30] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[38] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[40] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[48] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[50] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[58] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[60] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[68] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[70] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[78] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[80] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[88] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[90] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[98] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[A0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[A8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[B0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[B8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[C0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[C8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[D0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[D8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[E0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[E8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[F0] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[F8] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
TX[0] debug registers:
FE[0] debug registers:
PE[0] debug registers:
[00] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[08] D0000000 00000000 00000000 43690ACC BABEF00D BABEF00D BABEF00D BABEF00D
[10] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[18] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[20] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[28] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[30] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[38] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[40] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[48] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[50] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[58] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[60] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[68] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[70] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[78] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[80] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[88] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[90] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[98] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[A0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[A8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[B0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[B8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[C0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[C8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[D0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[D8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[E0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[E8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
[F0] 00000000 00000000 00000000 00000000 A99ACE42 ABC54001 BCA50884 CDE40190
[F8] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
PE[1] debug registers:
[08] D0000000 00000000 00000000 00000000 BABEF00D BABEF00D BABEF00D BABEF00D
DE[0] debug registers:
SH[0] debug registers:
PA[0] debug registers:
SE[0] debug registers:
MC[0] debug registers:
[00] 00000000 00000000 1E3353DD 5D1F5742 12345678 12345678 12345678 12345678
[08] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[10] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[18] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[20] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[28] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[30] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[38] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[40] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[48] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[50] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[58] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[60] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[68] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[70] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[78] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[80] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[88] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[90] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[98] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[A0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[A8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[B0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[B8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[C0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[C8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[D0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[D8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[E0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[E8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
[F0] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
[F8] 12345678 12345678 12345678 12345678 12345678 12345678 12345678 12345678
MC[1] debug registers:
[00] 00000000 00000000 00000000 00000000 12345678 12345678 12345678 12345678
HI[0] debug registers:
[00] 04037697 B9DE6FE4 CC080522 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[08] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[10] 00000001 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[18] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[20] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[28] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[30] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[38] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[40] 00000001 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[48] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[50] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[58] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[60] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[68] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[70] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[78] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[80] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[88] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[90] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[98] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[A0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[A8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[B0] 00000001 00000000 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[B8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[C0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[C8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[D0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[D8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[E0] 00000001 00000001 00000001 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[E8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[F0] 00000000 00000000 00000000 AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
[F8] AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA AAAAAAAA
TPG[1] debug registers:
TFB[1] debug registers:
USC[1] debug registers:
L2[0] debug registers:
BLT[0] debug registers:
Other Registers[0]:
[0x0040] 0x02B903DF
[0x0044] 0x061FC3C2
[0x004C] 0x061FC3C2
[0x0050] 0x01ACEE72
[0x0054] 0x01ACEE72
[0x0058] 0x02B903DF
[0x005C] 0x00B73A97
[0x0060] 0x00B73A97
[0x043C] 0x000000CC
[0x0440] 0x00000000
[0x0444] 0x00000000
[0x0414] 0x3C000000
[0x0100] 0x00140021
MMU status from MC[0]:
MTLB entry = 828
STLB entry = 768
PRE_STACK:
CMD_STACK:
LINK_STACK:
***** SW COUNTERS *****
Execute Count = 0x00002F56
Execute Addr = 0x2AF0FD80
End Addr = 0x2AF0FD70
CPU: 3 PID: 62 Comm: galcore deamon Not tainted 4.1.15-V1.3 #1
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[<800170b8>] (unwind_backtrace) from [<80012684>] (show_stack+0x10/0x14)
[<80012684>] (show_stack) from [<805ad65c>] (dump_stack+0x84/0x94)
[<805ad65c>] (dump_stack) from [<804464b4>] (gckOS_DumpCallStack+0x8/0x10)
[<804464b4>] (gckOS_DumpCallStack) from [<8046a7c0>] (gckHARDWARE_DumpGPUState+0x7e8/0x9ec)
[<8046a7c0>] (gckHARDWARE_DumpGPUState) from [<80456c20>] (gckEVENT_Notify+0x440/0x504)
[<80456c20>] (gckEVENT_Notify) from [<8046cdb8>] (gckHARDWARE_Interrupt+0x78/0x134)
[<8046cdb8>] (gckHARDWARE_Interrupt) from [<80441970>] (threadRoutine+0x28/0x78)
[<80441970>] (threadRoutine) from [<8004312c>] (kthread+0xe0/0xf8)
[<8004312c>] (kthread) from [<8000f228>] (ret_from_fork+0x14/0x2c)
*** GPU DRV CONFIG ***
Galcore version 6.2.2.93313
Galcore options:
irqLine = 309
registerMemBase = 0x00130000
registerMemSize = 0x00004000
irqLine2D = 310
registerMemBase2D = 0x00134000
registerMemSize2D = 0x00004000
irqLineVG = 311
registerMemBaseVG = 0x02204000
registerMemSizeVG = 0x00004000
contiguousSize = 0x08000000
contiguousBase = 0x00000000
bankSize = 0x00000000
fastClear = -1
compression = -1
signal = 48
powerManagement = 1
baseAddress = 0x00000000
physSize = 0x80000000
logFileSize = 0 KB
recovery = 0
stuckDump = 0
gpuProfiler = 0
irqs = -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,
registerBases = 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x000000
00, 0x00000000,
registerSizes = 0x00000800, 0x00000800, 0x00000800, 0x00000800, 0x00000800, 0x00000800, 0x00000800, 0x00000800, 0x000008
00, 0x00000800,
chipIDs = 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0xFFFFFFFF, 0x
FFFFFFFF,
Build options:
gcdGPU_TIMEOUT = 20000
gcdGPU_2D_TIMEOUT = 20000
gcdINTERRUPT_STATISTIC = 1
axi = 0x00000080
idle = 0x7FFFFFF8
FE not idle
DE not idle
PE not idle
0xFA5CC2A0
dmaLow = 0x48000000
Debug registers:
** 538 printk messages dropped ** FA5CC120 : 00004000 00000000 00000000 00000000 40000000 00000000 00000000 00000000
** 1229 printk messages dropped ** FA5F9A58 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
** 1278 printk messages dropped ** FA6404E8 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
** 1296 printk messages dropped ** FA644F48 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE 00000000 080204BA FFFFFFFF
** 344 printk messages dropped ** FA6465D8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6465F8 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF0D0D0D 080204BA FFFFFFFF
FA646618 : FFFFFFFF FF0D0D0D 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA646638 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF0D0D0D
FA646658 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA646678 : 06000006 FF3A3A3A 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA646698 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6466B8 : 0801048D A0000006 20000100 FF3A3A3A 009C074D 01F00752 08010001 00000000
FA6466D8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6466F8 : 48000000 00000701 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A
FA646718 : 18000000 FF3A3A3A 18000000 FF505050 18000000 00000000 18000000 00000000
FA646738 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA646758 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA646778 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA646798 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA6467B8 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF 2D0D0D0D 080104B9 FFFFEFFF
FA6467D8 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6467F8 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA646818 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA646838 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA646858 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA646878 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA646898 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA6468B8 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA6468D8 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6468F8 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA646918 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AB1480
FA646938 : 000000B0 000000B0 0F00000F FF131313 080204A3 27AB9040 00000058 FF131313
FA646958 : 08014A70 00000058 080204A1 27AB7780 00000058 FF131313 08014A68 00000058
FA646978 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA646998 : 009000B0 00008000 00008000 FF131313 0803048A 27AF4F80 00000180 000000C0
FA6469B8 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA6469D8 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6469F8 : 015400B0 FF131313 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA646A18 : 08010E02 00000701 48000000 00000701 18000000 FF131313 18000000 FF131313
FA646A38 : 18000000 FF131313 18000000 FF121212 18000000 FF0D0D0D 18000000 FF0D0D0D
FA646A58 : 18000000 FF0D0D0D 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA646A78 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF0D0D0D
FA646A98 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA646AB8 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA646AD8 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA646AF8 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA646B18 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA646B38 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA646B58 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA646B78 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA646B98 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA646BB8 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA646BD8 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA646BF8 : 00000180 000000C0 07000007 00000000 080104AE 00000154 080104AF FFFFFEF8
FA646C18 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 00000000
FA646C38 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA646C58 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA646C78 : 080204AA 009C05AE 01F0074D FF3A3A3A 08010497 0020CCCC 080104A5 00000000
FA646C98 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF3A3A3A
FA646CB8 : 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A
FA646CD8 : 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A
FA646CF8 : 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF323232
FA646D18 : 18000000 FF0D0D0D 18000000 FF0D0D0D 40000006 2AF0F910
User Command Buffer: 40000143, FA604EA8 PID:877 app-vue-proxima
FA604EA8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA604EC8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA604EE8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA604F08 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA604F28 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA604F48 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF000000 080204BA FFFFFFFF
FA604F68 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA604F88 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF000000
FA604FA8 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA604FC8 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA604FE8 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA605008 : 0801048D A0000006 20000100 33383131 024005AA 039405AE 08010001 00000000
FA605028 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA605048 : 48000000 00000701 18000000 3032310A 18000000 310A3730 18000000 30313231
FA605068 : 18000000 32310A31 18000000 0A383132 18000000 3232310A 18000000 310A3432
FA605088 : 18000000 30333231 18000000 32310A31 18000000 0A333332 18000000 3332310A
FA6050A8 : 18000000 310A3833 18000000 30343231 18000000 32310A31 18000000 0A353532
FA6050C8 : 18000000 3532310A 18000000 310A3935 18000000 31363231 18000000 32310A32
FA6050E8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA605108 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA605128 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA605148 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA605168 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA605188 : 080104AF FFFFFEF8 08020498 0240074D 03940752 310A3834 080204BA FFFFFFFF
FA6051A8 : FFFFFFFF 33310A32 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6051C8 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 3834310A
FA6051E8 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA605208 : 06000006 3936310A 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA605228 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA605248 : 0801048D A0000006 20000100 0A363435 0240074D 03940752 08010001 00000000
FA605268 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA605288 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6052A8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6052C8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6052E8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605308 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605328 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA605348 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA605368 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA605388 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA6053A8 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA6053C8 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA6053E8 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA605408 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA605428 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA605448 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA605468 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA605488 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA6054A8 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27BACD40
FA6054C8 : 000000B0 000000B0 0F00000F FF000000 080204A3 27BB4900 00000058 FF000000
FA6054E8 : 08014A70 00000058 080204A1 27BB3040 00000058 FF000000 08014A68 00000058
FA605508 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA605528 : 009000B0 00008000 00008000 FF000000 0803048A 27B8CF40 00000180 000000C0
FA605548 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA605568 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA605588 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA6055A8 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA6055C8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6055E8 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA605608 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA605628 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA605648 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA605668 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA605688 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6056A8 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA6056C8 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA6056E8 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA605708 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA605728 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA605748 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA605768 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA605788 : 00000180 000000C0 07000007 FF000000 080104AE 00000154 080104AF FFFFFEF8
FA6057A8 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF000000
FA6057C8 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA6057E8 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA605808 : 080204AA 024005AE 0394074D FF000000 08010497 0020CCCC 080104A5 00000000
FA605828 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF000000
FA605848 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605868 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605888 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6058A8 : 18000000 FF000000 18000000 FF000000 40000004 2AF0F960
User Command Buffer: 40000146, FA646D50 PID:877 app-vue-proxima
FA646D50 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA646D70 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA646D90 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA646DB0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA646DD0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA646DF0 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF131313 080204BA FFFFFFFF
FA646E10 : FFFFFFFF FF131313 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA646E30 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF131313
FA646E50 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA646E70 : 06000006 FF131313 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA646E90 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA646EB0 : 0801048D A0000006 20000100 FF111111 009C05AA 01F005AE 08010001 00000000
FA646ED0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA646EF0 : 48000000 00000701 18000000 FF0D0D0D 18000000 FF0D0D0D 18000000 FF0D0D0D
FA646F10 : 18000000 FF0D0D0D 18000000 FF0D0D0D 18000000 FF0D0D0D 18000000 FF0D0D0D
FA646F30 : 18000000 FF0D0D0D 18000000 FF0D0D0D 18000000 FF0D0D0D 18000000 FF0D0D0D
FA646F50 : 18000000 FF0D0D0D 18000000 FF161616 18000000 FF3A3A3A 18000000 FF3A3A3A
FA646F70 : 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A 18000000 FF3A3A3A
FA646F90 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA646FB0 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA646FD0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA646FF0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA647010 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA647030 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 32310A32 080204BA FFFFFFFF
FA647050 : FFFFFFFF 3032310A 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA647070 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 30333231
FA647090 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA6470B0 : 06000006 30343231 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA6470D0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6470F0 : 0801048D A0000006 20000100 310A3836 009C074D 01F00752 08010001 00000000
FA647110 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA647130 : 48000000 00000701 18000000 0A393133 18000000 3233310A 18000000 310A3232
FA647150 : 18000000 35323331 18000000 33310A36 18000000 0A383233 18000000 3333310A
FA647170 : 18000000 310A3233 18000000 31343331 18000000 33310A33 18000000 0A353433
FA647190 : 18000000 3433310A 18000000 310A3834 18000000 30353331 18000000 33310A32
FA6471B0 : 18000000 0A363533 18000000 3533310A 18000000 310A3136 18000000 34363331
FA6471D0 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA6471F0 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF 0A383836 080104B9 FFFFEFFF
FA647210 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA647230 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA647250 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA647270 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA647290 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA6472B0 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA6472D0 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA6472F0 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA647310 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA647330 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA647350 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27A969C0
FA647370 : 000000B0 000000B0 0F00000F FF0C0C0C 080204A3 27A9E580 00000058 FF0C0C0C
FA647390 : 08014A70 00000058 080204A1 27A9CCC0 00000058 FF0C0C0C 08014A68 00000058
FA6473B0 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA6473D0 : 009000B0 00008000 00008000 FF383838 0803048A 27AF4F80 00000180 000000C0
FA6473F0 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA647410 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA647430 : 015400B0 FF3B3B3B 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA647450 : 08010E02 00000701 48000000 00000701 18000000 FF3B3B3B 18000000 FF3B3B3B
FA647470 : 18000000 FF3B3B3B 18000000 FF3B3B3B 18000000 FF3B3B3B 18000000 FF3B3B3B
FA647490 : 18000000 FF3B3B3B 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA6474B0 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF 00000000
FA6474D0 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA6474F0 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA647510 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA647530 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA647550 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA647570 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA647590 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA6475B0 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA6475D0 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA6475F0 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA647610 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA647630 : 00000180 000000C0 07000007 FF0C0C0C 080104AE 00000154 080104AF FFFFFEF8
FA647650 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF0C0C0C
FA647670 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA647690 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA6476B0 : 080204AA 009C05AE 01F0074D FF0C0C0C 08010497 0020CCCC 080104A5 00000000
FA6476D0 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF121212
FA6476F0 : 18000000 FF121212 18000000 FF121212 18000000 FF121212 18000000 FF121212
FA647710 : 18000000 FF121212 18000000 FF121212 18000000 FF121212 18000000 FF121212
FA647730 : 18000000 FF121212 18000000 FF121212 18000000 FF121212 18000000 FF121212
FA647750 : 18000000 FF121212 18000000 FF121212 40000002 2AF0F9B0
User Command Buffer: 40000144, FA6058E0 PID:877 app-vue-proxima
FA6058E0 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA605900 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA605920 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA605940 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA605960 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA605980 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF000000 080204BA FFFFFFFF
FA6059A0 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6059C0 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF000000
FA6059E0 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA605A00 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA605A20 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA605A40 : 0801048D A0000006 20000100 FF000000 024005AA 039405AE 08010001 00000000
FA605A60 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA605A80 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605AA0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605AC0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605AE0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605B00 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605B20 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA605B40 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA605B60 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA605B80 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA605BA0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA605BC0 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF000000 080204BA FFFFFFFF
FA605BE0 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA605C00 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA605C20 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA605C40 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA605C60 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA605C80 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA605CA0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA605CC0 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605CE0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605D00 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605D20 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605D40 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA605D60 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA605D80 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA605DA0 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA605DC0 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA605DE0 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA605E00 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA605E20 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA605E40 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA605E60 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA605E80 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA605EA0 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA605EC0 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA605EE0 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AD9480
FA605F00 : 000000B0 000000B0 0F00000F FF000000 080204A3 27AE1040 00000058 FF000000
FA605F20 : 08014A70 00000058 080204A1 27ADF780 00000058 FF000000 08014A68 00000058
FA605F40 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA605F60 : 009000B0 00008000 00008000 FF000000 0803048A 27B8CF40 00000180 000000C0
FA605F80 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA605FA0 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA605FC0 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA605FE0 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA606000 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA606020 : 18000000 FF1E1E1E 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA606040 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF1E1E1E
FA606060 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA606080 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA6060A0 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA6060C0 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6060E0 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA606100 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA606120 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA606140 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA606160 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA606180 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA6061A0 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA6061C0 : 00000180 000000C0 07000007 FF1E1E1E 080104AE 00000154 080104AF FFFFFEF8
FA6061E0 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF1E1E1E
FA606200 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA606220 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA606240 : 080204AA 024005AE 0394074D FF1E1E1E 08010497 0020CCCC 080104A5 00000000
FA606260 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E
FA606280 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6062A0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6062C0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6062E0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 40000008 2AF0FA00
User Command Buffer: 40000147, FA647788 PID:877 app-vue-proxima
FA647788 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6477A8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA6477C8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA6477E8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA647808 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA647828 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF0C0C0C 080204BA FFFFFFFF
FA647848 : FFFFFFFF FF0C0C0C 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA647868 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF3B3B3B
FA647888 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA6478A8 : 06000006 FF3B3B3B 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA6478C8 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6478E8 : 0801048D A0000006 20000100 FF3B3B3B 009C05AA 01F005AE 08010001 00000000
FA647908 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA647928 : 48000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
FA647948 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA647968 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA647988 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA6479A8 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA6479C8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6479E8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA647A08 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA647A28 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA647A48 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA647A68 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF3B3B3B 080204BA FFFFFFFF
FA647A88 : FFFFFFFF FF3B3B3B 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA647AA8 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF0B0B0B
FA647AC8 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA647AE8 : 06000006 FF0B0B0B 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA647B08 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA647B28 : 0801048D A0000006 20000100 FF0B0B0B 009C074D 01F00752 08010001 00000000
FA647B48 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA647B68 : 48000000 00000701 18000000 FF101010 18000000 FF101010 18000000 FF101010
FA647B88 : 18000000 FF101010 18000000 FF101010 18000000 FF101010 18000000 FF101010
FA647BA8 : 18000000 FF101010 18000000 FF101010 18000000 FF101010 18000000 FF101010
FA647BC8 : 18000000 FF101010 18000000 FF101010 18000000 FF101010 18000000 FF101010
FA647BE8 : 18000000 FF101010 18000000 FF101010 18000000 FF101010 18000000 FF101010
FA647C08 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA647C28 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF0B0B0B 080104B9 FFFFEFFF
FA647C48 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA647C68 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA647C88 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA647CA8 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA647CC8 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA647CE8 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA647D08 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA647D28 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA647D48 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA647D68 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA647D88 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AB1480
FA647DA8 : 000000B0 000000B0 0F00000F 00000000 080204A3 27AB9040 00000058 00000000
FA647DC8 : 08014A70 00000058 080204A1 27AB7780 00000058 00000000 08014A68 00000058
FA647DE8 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA647E08 : 009000B0 00008000 00008000 00000000 0803048A 27AF4F80 00000180 000000C0
FA647E28 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA647E48 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA647E68 : 015400B0 FF3C3C3C 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA647E88 : 08010E02 00000701 48000000 00000701 18000000 FF3C3C3C 18000000 FF3C3C3C
FA647EA8 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA647EC8 : 18000000 FF3C3C3C 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA647EE8 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF3C3C3C
FA647F08 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA647F28 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA647F48 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA647F68 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA647F88 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA647FA8 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA647FC8 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA647FE8 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA648008 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA648028 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA648048 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA648068 : 00000180 000000C0 07000007 FF101010 080104AE 00000154 080104AF FFFFFEF8
FA648088 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF0B0B0B
FA6480A8 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA6480C8 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA6480E8 : 080204AA 009C05AE 01F0074D FF0B0B0B 08010497 0020CCCC 080104A5 00000000
FA648108 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF0B0B0B
FA648128 : 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B
FA648148 : 18000000 FF1F1F1F 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648168 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648188 : 18000000 FF3C3C3C 18000000 FF3C3C3C 40000006 2AF0FA50
systemd-journald[152]: /dev/kmsg buffer overrun, some messages lost.
User Command Buffer: 40000145, FA606318 PID:877 app-vue-proxima
FA606318 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA606338 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA606358 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA606378 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA606398 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6063B8 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF1E1E1E 080204BA FFFFFFFF
FA6063D8 : FFFFFFFF FF1E1E1E 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6063F8 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF1E1E1E
FA606418 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA606438 : 06000006 FF1E1E1E 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA606458 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA606478 : 0801048D A0000006 20000100 FF1E1E1E 024005AA 039405AE 08010001 00000000
FA606498 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6064B8 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6064D8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6064F8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606518 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606538 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606558 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA606578 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA606598 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA6065B8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA6065D8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6065F8 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF1E1E1E 080204BA FFFFFFFF
FA606618 : FFFFFFFF FF1E1E1E 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA606638 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA606658 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA606678 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA606698 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6066B8 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA6066D8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6066F8 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606718 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606738 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606758 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606778 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606798 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA6067B8 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA6067D8 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6067F8 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA606818 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA606838 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA606858 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA606878 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA606898 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA6068B8 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA6068D8 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6068F8 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA606918 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27BACD40
FA606938 : 000000B0 000000B0 0F00000F FF1E1E1E 080204A3 27BB4900 00000058 FF1E1E1E
FA606958 : 08014A70 00000058 080204A1 27BB3040 00000058 FF1E1E1E 08014A68 00000058
FA606978 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA606998 : 009000B0 00008000 00008000 FF1E1E1E 0803048A 27B8CF40 00000180 000000C0
FA6069B8 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA6069D8 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6069F8 : 015400B0 FF1E1E1E 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA606A18 : 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E 18000000 FF1E1E1E
FA606A38 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA606A58 : 18000000 FF1E1E1E 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA606A78 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF1E1E1E
FA606A98 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA606AB8 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA606AD8 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA606AF8 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA606B18 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA606B38 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA606B58 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA606B78 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA606B98 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA606BB8 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA606BD8 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA606BF8 : 00000180 000000C0 07000007 FF1E1E1E 080104AE 00000154 080104AF FFFFFEF8
FA606C18 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF1E1E1E
FA606C38 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA606C58 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA606C78 : 080204AA 024005AE 0394074D FF1E1E1E 08010497 0020CCCC 080104A5 00000000
FA606C98 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E
FA606CB8 : 18000000 FF1E1E1E 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606CD8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606CF8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606D18 : 18000000 FF000000 18000000 FF000000 40000004 2AF0FAA0
User Command Buffer: 40000148, FA6481C0 PID:877 app-vue-proxima
FA6481C0 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6481E0 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA648200 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA648220 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA648240 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA648260 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE 00000000 080204BA FFFFFFFF
FA648280 : FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6482A0 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 00000000
FA6482C0 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA6482E0 : 06000006 FF484848 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA648300 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA648320 : 0801048D A0000006 20000100 FF3C3C3C 009C05AA 01F005AE 08010001 00000000
FA648340 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA648360 : 48000000 00000701 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648380 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA6483A0 : 18000000 FF3C3C3C 18000000 FF1C1C1C 18000000 FF0B0B0B 18000000 FF0B0B0B
FA6483C0 : 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B
FA6483E0 : 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B
FA648400 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA648420 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA648440 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA648460 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA648480 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6484A0 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF101010 080204BA FFFFFFFF
FA6484C0 : FFFFFFFF FF101010 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6484E0 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF0F0F0F
FA648500 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA648520 : 06000006 FF0B0B0B 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA648540 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA648560 : 0801048D A0000006 20000100 FF0B0B0B 009C074D 01F00752 08010001 00000000
FA648580 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6485A0 : 48000000 00000701 18000000 FF0B0B0B 18000000 FF0B0B0B 18000000 FF0B0B0B
FA6485C0 : 18000000 FF0B0B0B 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA6485E0 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648600 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648620 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA648640 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA648660 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF3C3C3C 080104B9 FFFFEFFF
FA648680 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6486A0 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA6486C0 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA6486E0 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA648700 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA648720 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA648740 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA648760 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA648780 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6487A0 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA6487C0 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27A969C0
FA6487E0 : 000000B0 000000B0 0F00000F FF3C3C3C 080204A3 27A9E580 00000058 FF3C3C3C
FA648800 : 08014A70 00000058 080204A1 27A9CCC0 00000058 FF3C3C3C 08014A68 00000058
FA648820 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA648840 : 009000B0 00008000 00008000 FF0A0A0A 0803048A 27AF4F80 00000180 000000C0
FA648860 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA648880 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6488A0 : 015400B0 FF0A0A0A 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA6488C0 : 08010E02 00000701 48000000 00000701 18000000 FF0A0A0A 18000000 FF0A0A0A
FA6488E0 : 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0B0B0B
FA648900 : 18000000 FF0C0C0C 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA648920 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF0F0F0F
FA648940 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA648960 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA648980 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA6489A0 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6489C0 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA6489E0 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA648A00 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA648A20 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA648A40 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA648A60 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA648A80 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA648AA0 : 00000180 000000C0 07000007 FF3C3C3C 080104AE 00000154 080104AF FFFFFEF8
FA648AC0 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF3C3C3C
FA648AE0 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA648B00 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA648B20 : 080204AA 009C05AE 01F0074D 00000000 08010497 0020CCCC 080104A5 00000000
FA648B40 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 00000000
FA648B60 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA648B80 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA648BA0 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA648BC0 : 18000000 00000000 18000000 00000000 40000007 2AF0FB08
User Command Buffer: 40000146, FA606D50 PID:877 app-vue-proxima
FA606D50 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA606D70 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA606D90 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA606DB0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA606DD0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA606DF0 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF1E1E1E 080204BA FFFFFFFF
FA606E10 : FFFFFFFF FF1E1E1E 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA606E30 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF000000
FA606E50 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA606E70 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA606E90 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA606EB0 : 0801048D A0000006 20000100 FF1E1E1E 024005AA 039405AE 08010001 00000000
FA606ED0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA606EF0 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606F10 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606F30 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606F50 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606F70 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA606F90 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA606FB0 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA606FD0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA606FF0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA607010 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA607030 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF000000 080204BA FFFFFFFF
FA607050 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA607070 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA607090 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA6070B0 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA6070D0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6070F0 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA607110 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA607130 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607150 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607170 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607190 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6071B0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6071D0 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA6071F0 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA607210 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA607230 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA607250 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA607270 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA607290 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA6072B0 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA6072D0 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA6072F0 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA607310 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA607330 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA607350 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AD9480
FA607370 : 000000B0 000000B0 0F00000F FF000000 080204A3 27AE1040 00000058 FF000000
FA607390 : 08014A70 00000058 080204A1 27ADF780 00000058 FF000000 08014A68 00000058
FA6073B0 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA6073D0 : 009000B0 00008000 00008000 FF000000 0803048A 27B8CF40 00000180 000000C0
FA6073F0 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA607410 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA607430 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA607450 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA607470 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607490 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA6074B0 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA6074D0 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA6074F0 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA607510 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA607530 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA607550 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA607570 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA607590 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA6075B0 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA6075D0 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA6075F0 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA607610 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA607630 : 00000180 000000C0 07000007 FF000000 080104AE 00000154 080104AF FFFFFEF8
FA607650 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF000000
FA607670 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA607690 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA6076B0 : 080204AA 024005AE 0394074D FF000000 08010497 0020CCCC 080104A5 00000000
FA6076D0 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF000000
FA6076F0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607710 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607730 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607750 : 18000000 FF000000 18000000 FF000000 40000005 2AF0FB58
User Command Buffer: 40000149, FA648BF8 PID:877 app-vue-proxima
FA648BF8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA648C18 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA648C38 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA648C58 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA648C78 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA648C98 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF3C3C3C 080204BA FFFFFFFF
FA648CB8 : FFFFFFFF FF0A0A0A 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA648CD8 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF0A0A0A
FA648CF8 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA648D18 : 06000006 FF0A0A0A 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA648D38 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA648D58 : 0801048D A0000006 20000100 FF0A0A0A 009C05AA 01F005AE 08010001 00000000
FA648D78 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA648D98 : 48000000 00000701 18000000 FF0C0C0C 18000000 FF0C0C0C 18000000 FF0D0D0D
FA648DB8 : 18000000 FF0D0D0D 18000000 FF0C0C0C 18000000 FF0C0C0C 18000000 FF0B0B0B
FA648DD8 : 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A
FA648DF8 : 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A
FA648E18 : 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A 18000000 FF0A0A0A
FA648E38 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA648E58 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA648E78 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA648E98 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA648EB8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA648ED8 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF3C3C3C 080204BA FFFFFFFF
FA648EF8 : FFFFFFFF FF3C3C3C 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA648F18 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF3C3C3C
FA648F38 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA648F58 : 06000006 FF3C3C3C 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA648F78 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA648F98 : 0801048D A0000006 20000100 00000000 009C074D 01F00752 08010001 00000000
FA648FB8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA648FD8 : 48000000 00000701 18000000 00000000 18000000 00000000 18000000 00000000
FA648FF8 : 18000000 00000000 18000000 0000000A 18000000 00000000 18000000 00000000
FA649018 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA649038 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA649058 : 18000000 00000000 18000000 912B2B2B 18000000 FF4A4A4A 18000000 FF3C3C3C
FA649078 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA649098 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF3C3C3C 080104B9 FFFFEFFF
FA6490B8 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6490D8 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA6490F8 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA649118 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA649138 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA649158 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA649178 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA649198 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA6491B8 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6491D8 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA6491F8 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AB1480
FA649218 : 000000B0 000000B0 0F00000F FF090909 080204A3 27AB9040 00000058 FF090909
FA649238 : 08014A70 00000058 080204A1 27AB7780 00000058 FF090909 08014A68 00000058
FA649258 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA649278 : 009000B0 00008000 00008000 FF090909 0803048A 27AF4F80 00000180 000000C0
FA649298 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA6492B8 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6492D8 : 015400B0 FF090909 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA6492F8 : 08010E02 00000701 48000000 00000701 18000000 FF090909 18000000 FF090909
FA649318 : 18000000 FF090909 18000000 FF090909 18000000 FF090909 18000000 FF090909
FA649338 : 18000000 FF3C3C3C 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA649358 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF3C3C3C
FA649378 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA649398 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA6493B8 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA6493D8 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6493F8 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA649418 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA649438 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA649458 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA649478 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA649498 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA6494B8 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA6494D8 : 00000180 000000C0 07000007 00000000 080104AE 00000154 080104AF FFFFFEF8
FA6494F8 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF3C3C3C
FA649518 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA649538 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA649558 : 080204AA 009C05AE 01F0074D FF3C3C3C 08010497 0020CCCC 080104A5 00000000
FA649578 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF3C3C3C
FA649598 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA6495B8 : 18000000 FF393939 18000000 FF090909 18000000 FF090909 18000000 FF090909
FA6495D8 : 18000000 FF090909 18000000 FF090909 18000000 FF090909 18000000 FF090909
FA6495F8 : 18000000 FF090909 18000000 FF090909 40000003 2AF0FBA8
User Command Buffer: 40000147, FA607788 PID:877 app-vue-proxima
FA607788 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6077A8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA6077C8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA6077E8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA607808 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA607828 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF000000 080204BA FFFFFFFF
FA607848 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA607868 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF000000
FA607888 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA6078A8 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA6078C8 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6078E8 : 0801048D A0000006 20000100 FF000000 024005AA 039405AE 08010001 00000000
FA607908 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA607928 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607948 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607968 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607988 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6079A8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6079C8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6079E8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA607A08 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA607A28 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA607A48 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA607A68 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF000000 080204BA FFFFFFFF
FA607A88 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA607AA8 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA607AC8 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA607AE8 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA607B08 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA607B28 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA607B48 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA607B68 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607B88 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607BA8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607BC8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607BE8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607C08 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA607C28 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA607C48 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA607C68 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA607C88 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA607CA8 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA607CC8 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA607CE8 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA607D08 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA607D28 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA607D48 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA607D68 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA607D88 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27BACD40
FA607DA8 : 000000B0 000000B0 0F00000F FF000000 080204A3 27BB4900 00000058 FF000000
FA607DC8 : 08014A70 00000058 080204A1 27BB3040 00000058 FF000000 08014A68 00000058
FA607DE8 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA607E08 : 009000B0 00008000 00008000 FF000000 0803048A 27B8CF40 00000180 000000C0
FA607E28 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA607E48 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA607E68 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA607E88 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA607EA8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA607EC8 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA607EE8 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA607F08 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA607F28 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA607F48 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA607F68 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA607F88 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA607FA8 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA607FC8 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA607FE8 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA608008 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA608028 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA608048 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA608068 : 00000180 000000C0 07000007 FF1E1E1E 080104AE 00000154 080104AF FFFFFEF8
FA608088 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF1E1E1E
FA6080A8 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA6080C8 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA6080E8 : 080204AA 024005AE 0394074D FF1E1E1E 08010497 0020CCCC 080104A5 00000000
FA608108 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E
FA608128 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608148 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608168 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608188 : 18000000 FF1E1E1E 18000000 FF1E1E1E 40000009 2AF0FBF8
User Command Buffer: 4000014A, FA649630 PID:877 app-vue-proxima
FA649630 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA649650 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA649670 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA649690 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA6496B0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6496D0 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF090909 080204BA FFFFFFFF
FA6496F0 : FFFFFFFF FF090909 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA649710 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF090909
FA649730 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA649750 : 06000006 FF090909 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA649770 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA649790 : 0801048D A0000006 20000100 FF090909 009C05AA 01F005AE 08010001 00000000
FA6497B0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6497D0 : 48000000 00000701 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA6497F0 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA649810 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA649830 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA649850 : 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C 18000000 FF3C3C3C
FA649870 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA649890 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA6498B0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA6498D0 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA6498F0 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA649910 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 00000000 080204BA FFFFFFFF
FA649930 : FFFFFFFF 00000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA649950 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 EF4F4F4F
FA649970 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA649990 : 06000006 FF3D3D3D 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA6499B0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA6499D0 : 0801048D A0000006 20000100 FF3D3D3D 009C074D 01F00752 08010001 00000000
FA6499F0 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA649A10 : 48000000 00000701 18000000 FF3D3D3D 18000000 FF3D3D3D 18000000 FF3D3D3D
FA649A30 : 18000000 FF3D3D3D 18000000 FF3D3D3D 18000000 FF272727 18000000 FF080808
FA649A50 : 18000000 FF080808 18000000 FF080808 18000000 FF080808 18000000 FF080808
FA649A70 : 18000000 FF080808 18000000 FF080808 18000000 FF080808 18000000 FF080808
FA649A90 : 18000000 FF080808 18000000 FF080808 18000000 FF080808 18000000 FF080808
FA649AB0 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA649AD0 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF080808 080104B9 FFFFEFFF
FA649AF0 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA649B10 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA649B30 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA649B50 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA649B70 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA649B90 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA649BB0 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA649BD0 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA649BF0 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA649C10 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA649C30 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27A969C0
FA649C50 : 000000B0 000000B0 0F00000F FF3D3D3D 080204A3 27A9E580 00000058 FF3D3D3D
FA649C70 : 08014A70 00000058 080204A1 27A9CCC0 00000058 FF3D3D3D 08014A68 00000058
FA649C90 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA649CB0 : 009000B0 00008000 00008000 FF3D3D3D 0803048A 27AF4F80 00000180 000000C0
FA649CD0 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA649CF0 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA649D10 : 015400B0 00000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA649D30 : 08010E02 00000701 48000000 00000701 18000000 00000000 18000000 00000000
FA649D50 : 18000000 00000000 18000000 00000000 18000000 00000000 18000000 00000000
FA649D70 : 18000000 00000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA649D90 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF 00000000
FA649DB0 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA649DD0 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA649DF0 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA649E10 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA649E30 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA649E50 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA649E70 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA649E90 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA649EB0 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA649ED0 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA649EF0 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA649F10 : 00000180 000000C0 07000007 FF080808 080104AE 00000154 080104AF FFFFFEF8
FA649F30 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF080808
FA649F50 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA649F70 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA649F90 : 080204AA 009C05AE 01F0074D FF080808 08010497 0020CCCC 080104A5 00000000
FA649FB0 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF080808
FA649FD0 : 18000000 FF080808 18000000 FF080808 18000000 FF080808 18000000 FF080808
FA649FF0 : 18000000 FF080808 18000000 FF080808 18000000 FF000000 18000000 FF000000
FA64A010 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A030 : 18000000 FF000000 18000000 FF000000 40000007 2AF0FC48
User Command Buffer: 40000148, FA6081C0 PID:877 app-vue-proxima
FA6081C0 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA6081E0 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA608200 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA608220 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA608240 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA608260 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF1E1E1E 080204BA FFFFFFFF
FA608280 : FFFFFFFF FF1E1E1E 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6082A0 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF1E1E1E
FA6082C0 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA6082E0 : 06000006 FF1E1E1E 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA608300 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA608320 : 0801048D A0000006 20000100 FF1E1E1E 024005AA 039405AE 08010001 00000000
FA608340 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA608360 : 48000000 00000701 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608380 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6083A0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6083C0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6083E0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608400 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA608420 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA608440 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA608460 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA608480 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA6084A0 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF1E1E1E 080204BA FFFFFFFF
FA6084C0 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA6084E0 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA608500 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA608520 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA608540 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA608560 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA608580 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA6085A0 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6085C0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6085E0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA608600 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608620 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608640 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA608660 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA608680 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6086A0 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA6086C0 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA6086E0 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA608700 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA608720 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA608740 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA608760 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA608780 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6087A0 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA6087C0 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AD9480
FA6087E0 : 000000B0 000000B0 0F00000F FF000000 080204A3 27AE1040 00000058 FF000000
FA608800 : 08014A70 00000058 080204A1 27ADF780 00000058 FF1E1E1E 08014A68 00000058
FA608820 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA608840 : 009000B0 00008000 00008000 FF1E1E1E 0803048A 27B8CF40 00000180 000000C0
FA608860 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA608880 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6088A0 : 015400B0 FF1E1E1E 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA6088C0 : 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E 18000000 FF1E1E1E
FA6088E0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608900 : 18000000 FF1E1E1E 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA608920 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF1E1E1E
FA608940 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA608960 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA608980 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA6089A0 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6089C0 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA6089E0 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA608A00 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA608A20 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA608A40 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA608A60 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA608A80 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA608AA0 : 00000180 000000C0 07000007 FF1E1E1E 080104AE 00000154 080104AF FFFFFEF8
FA608AC0 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF1E1E1E
FA608AE0 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA608B00 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA608B20 : 080204AA 024005AE 0394074D FF1E1E1E 08010497 0020CCCC 080104A5 00000000
FA608B40 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF1E1E1E
FA608B60 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608B80 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608BA0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608BC0 : 18000000 FF1E1E1E 18000000 FF1E1E1E 40000005 2AF0FC98
User Command Buffer: 40000143, FA64A068 PID:877 app-vue-proxima
FA64A068 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA64A088 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA64A0A8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA64A0C8 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA64A0E8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA64A108 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF000000 080204BA FFFFFFFF
FA64A128 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA64A148 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF000000
FA64A168 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA64A188 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA64A1A8 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA64A1C8 : 0801048D A0000006 20000100 FF000000 009C05AA 01F005AE 08010001 00000000
FA64A1E8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA64A208 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A228 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A248 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A268 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A288 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A2A8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA64A2C8 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA64A2E8 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA64A308 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA64A328 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA64A348 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF000000 080204BA FFFFFFFF
FA64A368 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA64A388 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF000000
FA64A3A8 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA64A3C8 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA64A3E8 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA64A408 : 0801048D A0000006 20000100 FF000000 009C074D 01F00752 08010001 00000000
FA64A428 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA64A448 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A468 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A488 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A4A8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A4C8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A4E8 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA64A508 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA64A528 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA64A548 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA64A568 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA64A588 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA64A5A8 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA64A5C8 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA64A5E8 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA64A608 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA64A628 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA64A648 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA64A668 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27AB1480
FA64A688 : 000000B0 000000B0 0F00000F FF000000 080204A3 27AB9040 00000058 FF000000
FA64A6A8 : 08014A70 00000058 080204A1 27AB7780 00000058 FF000000 08014A68 00000058
FA64A6C8 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA64A6E8 : 009000B0 00008000 00008000 FF000000 0803048A 27AF4F80 00000180 000000C0
FA64A708 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA64A728 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA64A748 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA64A768 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA64A788 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64A7A8 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA64A7C8 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA64A7E8 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA64A808 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA64A828 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA64A848 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA64A868 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA64A888 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA64A8A8 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA64A8C8 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA64A8E8 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA64A908 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA64A928 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA64A948 : 00000180 000000C0 07000007 FF000000 080104AE 00000154 080104AF FFFFFEF8
FA64A968 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF000000
FA64A988 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA64A9A8 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA64A9C8 : 080204AA 009C05AE 01F0074D FF000000 08010497 0020CCCC 080104A5 00000000
FA64A9E8 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF000000
FA64AA08 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AA28 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AA48 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AA68 : 18000000 FF000000 18000000 FF000000 40000008 2AF0FD40
User Command Buffer: 40000060, FA5CC000 PID:877 app-vue-proxima
FA5CC000 : 08010E03 00000008 08010E02 00000701 48000000 00000701 08010E00 00000000
FA5CC020 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA5CC040 : 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF 310A3533 080104B9 FFFFEFFF
FA5CC060 : 084D0600 00000000 00000000 00004000 00000000 00000000 00000000 40000000
FA5CC080 : 00000000 00000000 00000000 00000000 00004000 00000000 00000000 00000000
FA5CC0A0 : 40000000 00000000 00000000 00000000 00000000 00004000 00000000 00000000
FA5CC0C0 : 00000000 40000000 00000000 00000000 00000000 00000000 00004000 00000000
FA5CC0E0 : 00000000 00000000 40000000 00000000 00000000 00000000 00000000 00004000
FA5CC100 : 00000000 00000000 00000000 40000000 00000000 00000000 00000000 00000000
FA5CC120 : 00004000 00000000 00000000 00000000 40000000 00000000 00000000 00000000
FA5CC140 : 00000000 00004000 00000000 00000000 00000000 40000000 00000000 00000000
FA5CC160 : 00000000 00000000 00004000 00000000 00000000 00000000 40000000 00000000
FA5CC180 : 00000000 00000000 00000000 00004000 00000000 00000000 08010488 00010000
FA5CC1A0 : 08014A60 000002D0 080104C0 00000000 08040480 CF300000 000002D0 000002D0
FA5CC1C0 : 0F00000F 3333370A 080204A3 CF37E900 00000168 3837370A 08014A70 00000168
FA5CC1E0 : 080204A1 CF365400 00000168 380A3336 08014A68 00000168 080104AE 00000240
FA5CC200 : 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000 024002D0 00008000
FA5CC220 : 00008000 0A646E75 0803048A 25000000 00001E00 00000780 080104E8 00000780
FA5CC240 : 080104AD 00000438 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000
FA5CC260 : 0801048D 80005006 080204AA 009C02AC 02DC057C 0A656572 08010497 0020CCCC
FA5CC280 : 080104A5 00000000 08010E03 00000008 08010E02 00000701 48000000 00000701
FA5CC2A0 : 18000000 74737973 18000000 690A7366 18000000 74707572 18000000 0A6D656D
FA5CC2C0 : 18000000 0A737472 18000000 6C6C616B 18000000 736D6B0A 18000000 63656761
FA5CC2E0 : 18000000 61706B0A 40000006 2AF0FD90
User Command Buffer: 40000149, FA608BF8 PID:877 app-vue-proxima
FA608BF8 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA608C18 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA608C38 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA608C58 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA608C78 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA608C98 : 080104AF FFFFFEF8 08020498 024005AA 039405AE FF1E1E1E 080204BA FFFFFFFF
FA608CB8 : FFFFFFFF FF1E1E1E 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA608CD8 : 080104B3 00000000 08010483 00000000 08020484 024005AA 01540004 FF000000
FA608CF8 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA608D18 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA608D38 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA608D58 : 0801048D A0000006 20000100 FF000000 024005AA 039405AE 08010001 00000000
FA608D78 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA608D98 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA608DB8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA608DD8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA608DF8 : 18000000 FF000000 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608E18 : 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E 18000000 FF1E1E1E
FA608E38 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA608E58 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA608E78 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA608E98 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA608EB8 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA608ED8 : 080104AF FFFFFEF8 08020498 0240074D 03940752 FF000000 080204BA FFFFFFFF
FA608EF8 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA608F18 : 080104B3 00000000 08010483 00000000 08020484 0240074D 01540005 FF000000
FA608F38 : 08014A60 00000010 080104C0 00000000 08040480 27A89B40 00000040 00000010
FA608F58 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA608F78 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA608F98 : 0801048D A0000006 20000100 FF000000 0240074D 03940752 08010001 00000000
FA608FB8 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA608FD8 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA608FF8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA609018 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA609038 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA609058 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA609078 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA609098 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA6090B8 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA6090D8 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA6090F8 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA609118 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA609138 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA609158 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA609178 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA609198 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA6091B8 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA6091D8 : 0000FFD0 00000000 00000000 00004000 00000000 00000000 08010489 00006BFC
FA6091F8 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27BACD40
FA609218 : 000000B0 000000B0 0F00000F FF000000 080204A3 27BB4900 00000058 FF000000
FA609238 : 08014A70 00000058 080204A1 27BB3040 00000058 FF000000 08014A68 00000058
FA609258 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA609278 : 009000B0 00008000 00008000 FF000000 0803048A 27B8CF40 00000180 000000C0
FA609298 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA6092B8 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA6092D8 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA6092F8 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA609318 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA609338 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA609358 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA609378 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA609398 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA6093B8 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA6093D8 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA6093F8 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA609418 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA609438 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA609458 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA609478 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA609498 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 00000000
FA6094B8 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27B8CF40
FA6094D8 : 00000180 000000C0 07000007 FF000000 080104AE 00000154 080104AF FFFFFEF8
FA6094F8 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF000000
FA609518 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA609538 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA609558 : 080204AA 024005AE 0394074D FF000000 08010497 0020CCCC 080104A5 00000000
FA609578 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF000000
FA609598 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6095B8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6095D8 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA6095F8 : 18000000 FF000000 18000000 FF000000 40000006 2AF0FDD0
User Command Buffer: 40000144, FA64AAA0 PID:877 app-vue-proxima
FA64AAA0 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA64AAC0 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA64AAE0 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA64AB00 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA64AB20 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA64AB40 : 080104AF FFFFFEF8 08020498 009C05AA 01F005AE FF000000 080204BA FFFFFFFF
FA64AB60 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA64AB80 : 080104B3 00000000 08010483 00000000 08020484 009C05AA 01540004 FF000000
FA64ABA0 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA64ABC0 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA64ABE0 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA64AC00 : 0801048D A0000006 20000100 FF000000 009C05AA 01F005AE 08010001 00000000
FA64AC20 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA64AC40 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AC60 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AC80 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64ACA0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64ACC0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64ACE0 : 08010E00 00000001 0803048A 25000000 00001E00 00000000 080104E8 00000780
FA64AD00 : 08010E03 00000008 080104AD 00000000 080104AF FFFFFDC7 080104E7 00000000
FA64AD20 : 080104C3 00000000 08014A98 00000000 08014A99 00000000 08014A9A 00000000
FA64AD40 : 08014A9B 00000000 08014A9C 00000000 08014A9D 00000000 08014A9E 00000000
FA64AD60 : 08014A9F 00000000 080104B1 00000000 080104B8 00000000 080104B0 FF000000
FA64AD80 : 080104AF FFFFFEF8 08020498 009C074D 01F00752 FF000000 080204BA FFFFFFFF
FA64ADA0 : FFFFFFFF FF000000 080104B5 00000000 080104B6 FFFFF6FF 08010497 0030CCCC
FA64ADC0 : 080104B3 00000000 08010483 00000000 08020484 009C074D 01540005 FF000000
FA64ADE0 : 08014A60 00000010 080104C0 00000000 08040480 27A89100 00000040 00000010
FA64AE00 : 06000006 FF000000 08010E03 00000008 080104AE 00000004 080104AF FFFFFEF8
FA64AE20 : 080104B6 FFFFFF64 0801049F 00000000 080104B4 00200000 080104AF FFF44FFF
FA64AE40 : 0801048D A0000006 20000100 FF000000 009C074D 01F00752 08010001 00000000
FA64AE60 : 08010001 00000000 08010001 00000000 08010E03 00000008 08010E02 00000701
FA64AE80 : 48000000 00000701 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AEA0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AEC0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AEE0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AF00 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64AF20 : 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000 080104AF FFF44FFF
FA64AF40 : 080104B4 00000000 080204BA FFFFFFFF FFFFFFFF FF000000 080104B9 FFFFEFFF
FA64AF60 : 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000 F5C103AC 2A2E24F9
FA64AF80 : 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405 FF670000 F6BE0349
FA64AFA0 : 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D FF03040E FF8C0000
FA64AFC0 : F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB F5483592 FEFE03E7
FA64AFE0 : FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF 1217FA23 F641392D
FA64B000 : FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17 0176FFDB 0CFEFBAB
FA64B020 : F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC 0000FF3F 00EDFFF0
FA64B040 : 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC 01B6FB3D 0000FF7D
FA64B060 : 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035 3FE301DE 009DFE45
FA64B080 : 0000FFD0 00000000 00000000 00004000 00000000 6B800000 08010489 00006BFC
FA64B0A0 : 080104B9 FFFFFFF4 08014A60 000000B0 080104C0 00000000 08040480 27A969C0
FA64B0C0 : 000000B0 000000B0 0F00000F FF000000 080204A3 27A9E580 00000058 FF000000
FA64B0E0 : 08014A70 00000058 080204A1 27A9CCC0 00000058 FF000000 08014A68 00000058
FA64B100 : 080104AE 00000090 080104AF FFFFFEF8 080104B6 FFFFFF64 080404A6 00000000
FA64B120 : 009000B0 00008000 00008000 FF000000 0803048A 27AF4F80 00000180 000000C0
FA64B140 : 080104E8 000000C0 080104AD 00000154 080104AF FFFFFDC7 080104CB FFFFFF67
FA64B160 : 080104E7 00000000 080104C3 00000000 0801048D 80006007 080204AA 00000000
FA64B180 : 015400B0 FF000000 08010497 0020CCCC 080104A5 00000001 08010E03 00000008
FA64B1A0 : 08010E02 00000701 48000000 00000701 18000000 FF000000 18000000 FF000000
FA64B1C0 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64B1E0 : 18000000 FF000000 08010E00 00000001 080104B6 FFFFF6FF 0801049F 00000000
FA64B200 : 080104AF FFF44FFF 080104B4 00200000 080204BA FFFFFFFF FFFFFFFF FF000000
FA64B220 : 080104B9 FFFFEFFF 084D0600 03D3FF32 279AF561 F561279A FF3203D3 FF420000
FA64B240 : F5C103AC 2A2E24F9 03F1F517 0000FF22 037EFF54 224BF637 F4E62CAC FF150405
FA64B260 : FF670000 F6BE0349 2F121F95 040FF4D1 0000FF0B 030FFF79 1CDBF756 F4D9315D
FA64B280 : FF03040E FF8C0000 F7FB02D0 33881A21 0401F500 0000FEFF 028EFF9E 176AF8AB
FA64B2A0 : F5483592 FEFE03E7 FFAF0000 F9640249 377414BB 03C0F5B3 0000FF02 0203FFBF
FA64B2C0 : 1217FA23 F641392D FF0A038C FFCE0000 FAE601BC 3ABA0F81 034AF6F4 0000FF17
FA64B2E0 : 0176FFDB 0CFEFBAB F7CD3C18 FF2802F9 FFE70000 FC6F0130 3D450A8F 029BF8CC
FA64B300 : 0000FF3F 00EDFFF0 0839FD31 F9F13E3E FF5B022F FFF70000 FDF000AC 3F0105FC
FA64B320 : 01B6FB3D 0000FF7D 006FFFFC 03DDFEA8 FCAE3F8E FFA40130 FFFF0000 FF590035
FA64B340 : 3FE301DE 009DFE45 0000FFD0 00000000 00000000 00004000 00000000 C84C0000
FA64B360 : 08010488 00006C36 08014A60 000000C0 080104C0 00000000 08040480 27AF4F80
FA64B380 : 00000180 000000C0 07000007 FF000000 080104AE 00000154 080104AF FFFFFEF8
FA64B3A0 : 080104B6 FFFFFF64 080404A6 00000000 015400B0 00008000 00008000 FF000000
FA64B3C0 : 0803048A 25000000 00001E00 00000780 080104E8 00000780 080104AD 00000438
FA64B3E0 : 080104AF FFFFFDC7 080104E7 00000000 080104C3 00000000 0801048D 80005006
FA64B400 : 080204AA 009C05AE 01F0074D FF000000 08010497 0020CCCC 080104A5 00000000
FA64B420 : 08010E03 00000008 08010E02 00000701 48000000 00000701 18000000 FF000000
FA64B440 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64B460 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64B480 : 18000000 FF000000 18000000 FF000000 18000000 FF000000 18000000 FF000000
FA64B4A0 : 18000000 FF000000 18000000 FF000000 40000009 2AF0FDF8
*** EVENT STATE DUMP ***
Unsumbitted Event:
Untriggered Event:
[0]:
gcvHAL_COMMIT_DONE
[1]:
gcvHAL_SIGNAL process=17 signal=0x36d
[2]:
gcvHAL_COMMIT_DONE
[3]:
gcvHAL_COMMIT_DONE
[4]:
[5]:
[6]:
[7]:
[8]:
[9]:
[10]:
[11]:
[12]:
[13]:
[14]:
[15]:
[16]:
[17]:
[18]:
[19]:
[20]:
[21]:
[22]:
[23]:
[24]:
[25]:
[26]:
[27]:
[28]:
Number of Pending Interrupt: 6
INTR_ACKNOWLEDGE=0x0
Notify State=-1
Pending=0x40000000
*** PROCESS DB DUMP ***
PID NAME
880 app-settings
881 app-message
1474 chromium
694 Xorg
872 app-master
873 app-tourelleau
875 app-vhp
876 app-wheelmenu
877 app-vue-proxima
879 app-wheelmenu
[galcore]: Stop driver to keep scene.
systemd-journald[152]: /dev/kmsg buffer overrun, some messages lost.
And the bandwith between the IPU and the memory ?
this depends on use case, you can try to test with baremetal sdk.
The problem is not the VPU because the problem appear only when we add a framebuffer to use an overlay on the video.
We suspect the IPU. Is it possible to the IPU to manage two framebuffers with 1080p@60Hz on HDMI?
from IPU hardware there are no restrictons for that.
Hi Vincent
for vpu theoretical performance one can look at presentation below p.18 :
2 x 1080p@30Hz
However this may depend on bus loading (use case).
