I am using TWR-KE18F board. I looked for Kinetis Design Studio and MCUxpresso IDEs but I couldn't find how to generate startup or initialization codes. Is there any other way to obtain these codes?
If no way to obtain these codes from manufacturer due to not supporting, I am curious about the reason behind this? Is this procedure not applicable for the processor or is the processor too old for this application. If the reason is processor-based, I can change the processor before starting my project.
Last thing I think about this issue is; can I use any other processor that have similar pin-outs and necessary hardware and also supported by the manufacturer for this code generation issue.
Thanks in advance,
Onur
Solved! Go to Solution.
You can both use KDS and MCUXpresso IDE to develop the TWR-KE18 board.
There is MCUXpresso SDK MCUXpresso SDK|NXP , it not only includes the startup or initialization codes,
but also drivers and lost demos .
So first you need to download SDK package for TWR-KE18 from https://mcuxpresso.nxp.com/en/select ,
after downlaod , there is a quick start "Getting Started with MCUXpresso SDK.pdf" under SDK package ,
it describe how to use and run demo on KDS, MUCxpresso . Also the "MCUXpresso_IDE_User_Guide.pdf"
says how to use SDK on MCUXpresso IDE.
Hope it helps
TIC
Hi Alice,
I am partially satisfied with your answer. Thanks for it. However I am still wondering why we can't use the Peripheral part of ConfigTool. It would be very easy and time-efficient by adjusting peripheral properties.
Onur
Hello Onur,
As to the MCUXpresso Config Tool is a new software , it only support parts of NXP chips,
the others will continue be released .
About the supported update , you can follow this thread :
https://community.nxp.com/docs/DOC-333073
Hope it helps
Alice
Hope it helps
TIC
