I'm facing the SSP polarity issue in a board based in i.mx28 so I would like to test the SSP Polarity Rom Patch that is quoted in several POST in this community (Ex: https://community.nxp.com/thread/303412).
Unfortunately all the links seems to be broken...
Do you know where I can still find this patch (mx28_ssppolarity_rompatch_up.zip) ?
Thankyou for your support.
Danilo
Hello Danilo,
Would you please open a support Case asking for this file? I’ll check why it was taken down but in case it’s still available it’s easier to share it through a Case.
thank you for the suggestion, the case is filed with id: 00159021.
Danilo
