您好
porting TC358743 Driver open camera app 遇到"ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0"
1、SDK 是使用m6.0.1_2.0.0-ga android6.0
2、TC358743 driver 從boundarydevices下載,並修改
3、參考Debug steps for customer MIPI sensor.pdf & MIPI–CSI2 Peripheral on i.MX6 MPUs.pdf 兩份文件,進行修改及確認相關mipi 設定。
4、Mipi clk and Data 訊號都有出來(1024x768@60)
請問IMX6DL 還需要在確認那一些register???
還是HAL部份沒有作好設定所造成嗎???
有用其他App open /dev/video1 一樣會出現"ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0"
請協助,謝細
Hi Joan
這一篇有參考過,狀況一樣
使用mxc-v4l2-tvin -ol 0 -ot 0 -ow 1024 -oh 768 -d 1 -x 1 -f YUYV
並參考Debug steps for customer MIPI sensor.pdf,將相關的register print 出來
是否有相關的register設定有問題才會造成,以下相關的register設定數值
IPU_CONF = | 0x20000762 |
IDMAC_CONF = | 0x0000002F |
IDMAC_CHA_EN1 = | 0x00800002 |
IDMAC_CHA_EN2 = | 0x00000000 |
IDMAC_CHA_PRI1 = | 0x18800003 |
IDMAC_CHA_PRI2 = | 0x00000000 |
IDMAC_BAND_EN1 = | 0x00000000 |
IDMAC_BAND_EN2 = | 0x00000000 |
IPU_CHA_DB_MODE_SEL0 | 0x00000002 |
IPU_CHA_DB_MODE_SEL1 | 0x00000000 |
IPU_CHA_TRB_MODE_SEL0 | 0x00800000 |
IPU_CHA_TRB_MODE_SEL1 | 0x00000000 |
DMFC_WR_CHAN = | 0x00000090 |
DMFC_WR_CHAN_DEF = | 0x202020F6 |
DMFC_DP_CHAN = | 0x000096CA |
DMFC_DP_CHAN_DEF = | 0x2020F6F6 |
DMFC_IC_CTRL = | 0x00000002 |
IPU_FS_PROC_FLOW1 = | 0x00000000 |
IPU_FS_PROC_FLOW2 = | 0x00000000 |
IPU_FS_PROC_FLOW3 = | 0x00000000 |
IPU_FS_DISP_FLOW1 = | 0x00000000 |
IPU_VDIC_VDI_FSIZE = | 0x00000000 |
IPU_VDIC_VDI_C = | 0x00000000 |
IPU_IC_CONF = | 0x00000000 |
SMFC_BS | 0x70 |
SMFC_MAP | 0x20 |
CSI1_MIPI_DI | 0xffffff1e |
CSI1_SENS_CONF | 0x920 |
CSI1_ACT_FRM_SIZE | 0x2ff03ff |
pls refer to the link as below, this is very useful for you
pls refer to the discussion as below, hope helpful for you
