I’m having some problems with the DDR when executing the code specially after configuring the EPIT driver the memcpy stop working, and when for example I use the secure monitor to go from ns to secure the code crash when doing the “movs lr” where lr has the address of a guest OS, so I wanted to ask what is the correct configuration of the DDR on the IMX6quad board.
kind regards
Ailton Lopes
use the following
As for memory tools:
https://community.nxp.com/docs/DOC-236354
It makes sense to check memory:
i.MX6/7 DDR Stress Test Tool V2.80
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
