Filter ID Message MSCAN - Processor Expert
carrielbr
Good Morning,
I am using the FRDM-KE06Z development board which has MSCAN.
Using Processor Expert I was able to receive and transmit data through the CAN perfectly.
What I can not do is understand how I can filter some specific CAN IDs.
For example, would you like to only get ID 0x7E8 what would the filters look like?
In the processor expert component has a function called CAN_SetRxIDFilterTable (Drv, ElementIndex, AccCode).
already tried to use this function with the values CAN_SetRxIDFilterTable (Drv, 0U, 0x7E8) and I continue to pick up all the IDs of the CAN bus and not only the 0x7E8.
Could someone help me by sending a sample code or helping me understand how it works?
Here is the screen print of my program and settings.
Thanks.
I have reply you on your another thread , please check it .
Filter ID Message MSCAN Processor Expert
TIC
