I come across the Low 2D graphics performance the same as this. After searching, I found a most possible solution at here. It is a patch for Android L5.0.0_1.0.0 that update GPU driver from 5.0.11p4 to 5.0.11p8 (as well as .so). However, this link contains only 2 documents. How can I get that patch?
Android OS for i.MX Applications Processors only provides resources from 6.0.1+ and provides no archived resources. 2D graphic on imx 6 Android L 5.x is very slow. I just can't update my whole system. Any help is welcome.
Hi boshen,
So sorry for late reply. In the Android OS for i.MX Applications Processors only the newer released version android BSP, the old BSP have been moved. About the Android L5.0.0_1.0.0 I have searched it for you, you can download the BSP and https://www.nxp.com/webapp/sps/download/preDownload.jsp
Hope this can do help for you. Any questions you can continue contact me.
Rita
