Writing your first touch sensing application
Document describing first steps of simple touch sensing application in Code Warrior and TWR board is attached.
We will use
the proces is described in detail and final code is attached for easy jump into the topic
Pavel Sadek
Comments
Thank you for your work on this Pavel. I look forward to playing with the code/example.
David
Appreciate having a document.
The links to the latest TSS are out of date.
I'm using KDS2 with a custom MK20DX256xx7 and I think that has a later version of the libraries. However the KDS2 libraries didn't compile the first time - the asm() needed changing to __asm()
For a simple concept of wanting one touch electrode, there seems to be a big learning curve.
No ratings
Version history
Last update:
‎11-18-2013 02:53 AM
Updated by:
