Interfacing wirelessly your Freedom FRDM-KL46Z over Bluetooth to Freemaster
Document created by Puebla Palma Luis Employee on Nov 11, 2013Last modified by ebiz_ws_prod on Dec 13, 2017
Version 4Show Document
  • View in full screen mode
This example shows a FRDM-KL46Z interfacing with a Bluetooth-serial board BT_BOARD V1.05, it uses FREEMASTER to graph temperature and light sensor variables.
Check how to connect, configure Bluetooth, and freemaster in attached document
FRDM-KL46Z-Bluetooth-Freemaster.zip contains
                           srec file
                           firmware
                           fremaster project (.pmp)
Luis
Original Attachment has been moved to: FRDM-KL46Z-Bluetooth-Freemaster.zip
1 person found this helpful
Outcomes
